1929 Model D/JD
Don E. Foster
08-25-2006 10:11:33
Have a '29 JD/D that is firing only on # 1. Have spark so assume is tappet. I know I need a tappet adjusting clamp as the old one is stretched out so when tight shut still doesn't hold the adjuster too tight. That is probably my problem.
But I also have new Autolite plugs # 3095. Seem same demensions as the original take-apart plug but won't screw into the block nearly as far. Maybe tappered thread???? Any advice on this.
I am 85 and really pulled a back muscle starting the darned thing. It has been completely overhauled. So I use a McCormick and belt then clutch the old boy in. Saves on doctor bills. Then I have an "elected" (not electric) starter. Dennis Natal, down the road. When he comes up we start old JD/D!!!!
I suspect Bob Lee back in Kansas will see this and know what to do. He's the guy that restored the thing!!!!
Bobl1958
08-25-2006 12:47:12
 Re: 1929 Model D/JD in reply to Don E. Foster, 08-25-2006 10:11:33
Hey, Don. Glad to see you're still playing with the old tractors. I will be out in your neck of the woods the end of Sept, so I'll make it a point to stop in and check the old girl out whether you have it fixed or not. Like Glen said, you can get a new bolt and cup for the tappet lever pretty easy. I'll look and see if I have one. Maybe see if I can come up with the whole lever. They get worn on the ends and then not enough to tighten up. Did you check to see if you had good spark at the plug itself? Email me Don with your phone # and we will see what we can do. Take care-Bob
Glen in TX
08-25-2006 12:09:25
Don, A new bolt and retapping threads in tappet lever might help. Believe it not but same tappet lever D179R, casting number D88R used on all Ds 30400 and up to the last 53 model so not a hard item to find.
Early Ds used a 1/2 inch taper pipe thread spark plug. Autolite 3095 is cross to the Champion 25 now still made and the earlier Champion A-25. You can find other NOS original plugs for it from vendors like Don McKinsey who advertises in some of the magazines. Sometimes plugs get fouled from overchoking or rich running and you just clean them or on many of these newer plugs just replace them with a fresh set.
Lots of nice electric start Ds still around. Even a young guy can hurt himself trying to start a old D.
