4640 SCV SWAP
Harvey Young
08-25-2006 09:00:51
I have a 4640 with 3 scv's. The #1 scv has gone bad. I want to know if I can take the #3 and swap it with the #1 SCV? I never use more than 2 SCV's at a time so I can do without one. I just want the #1 working so the first lever in the cab works. If the swap is possible, how much work is it to change them? Any help or comments would be greatly appreciated.
Harvey
Bighead
08-26-2006 01:40:40
 Re: 4640 SCV SWAP in reply to Harvey Young, 08-25-2006 09:00:51
I think the levers may be different- you should be able to tell by looking. If that's the case, you'll have to swap the lever shafts, but it's a PITA to do without taking the valve apart. You'll need seals at a minimum. If you take the valve apart, you might as well rebuild it.
K.B.-826
08-25-2006 16:45:06
Yes it can be done, and it is very easy. Just unhook the linkage and remove the four bolts holding the SCV to the rockshaft housing.
