4010 update - got the wedge out, now how do I driv
TimS
08-25-2006 07:30:47
I used everyones advise that I found searching the old posts on here to get the wedge out of the rear wheel on my 4010, finally got it out last night.
Now the adjuster pinion seems to be rusted solid, I saw some messages that mentioned driving that shaft out, how do I go about doing that? What size is that shaft? ( Just wondering what to use size wise to drive it out... )
Mike M
08-25-2006 11:17:42
 Re: 4010 update - got the wedge out, now how do I in reply to TimS, 08-25-2006 07:30:47
Since you have the wedge out you can just lower the axle and move the wheel to where you need it. If you really want to get everything back moving again pull the whole wheel off and turn the pinion down and try to keep soaking it in penetrant. I have then had real good luck getting them moving again with a very large impact wrench. Or you can get a big bar/punch and drive them out. DO NOT HEAT the large casting as it will then crack easier. BTDT Good Luck !
Gerald J.
08-25-2006 09:49:31
I loosened one up on my 4020 a few weeks ago. I had the wedge loose, (which took driving it with the bolts loose) but the wheel still wouldn't move. I couldn't detect the gear was tight or loose, but my longest breaker bar with a piece of pipe on the handle didn't move the wheel. Since I had it jacked up, I turned the wheel to put the fixed wedge on top and lowered the jack to pull the axle loose from the wedge. It took a couple cycles of that to let me move the wheel. Then I moved the wheels all the way in and the next time getting the wedge loose is going to be a much bigger pain.
Gerald J.
jas
08-25-2006 09:46:20
We never take the wedge completly out. Just loosen it enough to where it has some gap around the axle. We also keep the teeth of the axle on top. With the wedge still in, it will keep the wheel from cocking and allow the gear to stay in mesh with the axle. But first it sounds like your going to have to work that pinion loose before you can attempt moving the wheel.
jturbo10
08-25-2006 07:55:27
Before you start driving out the pin you need to soak the pin area with lot of penetrating oil like Kroil or PB Blaster. I actually took my wheel off the axle using an engine hoist by taking the wedge and sleeve out and rotating the axle so it would slide out. Then I put lots of penetrating oil and mild heat and use a one inch super air wrench/gun to try and break up the rust but it would barely budge. I finally had to use two large drifts to get the shaft pin out. The shaft has a slot the matches the pinion wheel's built in key and you have to drive it off that wheel. Don't expect to get it out the first time you try to beat it out...it took about a month for mine to finally release. I'd just heat it a bit and beat it a lot every time I went by it and then soak it some more. Safety glasses, heavy gloves, and a sober attitude helps along with patience. Good luck
TimS
08-25-2006 07:31:59
 Re: 4010 update - wedge out, but pinion stuck in reply to TimS, 08-25-2006 07:30:47
Oops, the initial subject was to long
