Why did John Deere use Fords powershift transmissi
Ben Gubbels
08-25-2006 05:21:22
Why did John Deere use Ford's powershift design on the 3020's 4020's? Improved it nope more like stole it? I could be wrong but John Deere steals alot of patents from other tractor companies.
Deereday
09-03-2006 20:43:21
 Re: Why did John Deere use Fords powershift transm in reply to Ben Gubbels , 08-25-2006 05:21:22
There is a well distributed book or two by now of the life of Harold Brock who retired from Deere & Co., and was their first World Wide Head Of Engineering when he retired. He came there from Ford in the late 50"s. This puts a name to what others speak of. He wasn"t the only Ford Tractor Engineer to defect or quit in that set of years. To support some of what is said here about Brock telling For the SOS program needed more work/money thrown at it for the 6000 tractor and then larger models, I was a student of Ag Engineering professors at Michigan State in the late 60"s where some of the past actual employed engineers of Ford Tractor were then teaching at MSU, Lansing, which is just up the road a god hour from where Ford Tractor Operations was based at Birmingham, Michigan. One of the above mentioned professors at MSU who left Ford Tractor was Dewight Camp, of Williamson, Michigan, who may still be alive since Harold Brock is now 92 years old. Dewight Camp told us as student s back then that the Ford Engineers wanted the bean counters at Ford to allow them to develope a new version of Select-O-Speed that would be nased on wet clutch packs and not brake bands for the planet carriers to be controlled by. ANd they clearly wanted that for more reliability and longer trouble free service life. The auto based bean counters at Ford wanted to build tractors more like cars. Brock and his men did not. Since Brock was a long time friend of Henry Ford, the auto group wated till Henry Ford was out of country for three months, and with communications what they were in the 50"s, an alliance from the automotive branch at Ford made decission while Henry Ford was not aware to push Brock away. Others left too. Some on their own. IT WAS A GOOD DAY FOR TRACTOR HISTORY. BROCK FOUND SOMEONE AS PROGRESSIVE MINDED AS HIMSELF: "The John Deere Waterloo Tractor Works." .... And at the right time to come and hekp with what was ALREADY underway >>> POWER SHIFT.
Ha! Ha! Ha!
08-25-2006 18:12:53
Stuck yer teat in the wringer on that stupid post didn't ya!!! Ha! Ha! Ha! Now go eat some more of momma's grub so ya can grow up to be a big boy and learn somthin in skool to boot.Ford stole the Ferguson system didn't they? Course they never stole thAt one arm bandit loader.Nobody else was that stoopid to try buildin one first.
730virgil
08-25-2006 14:46:07
i don't know the whole story and what i have been told is true so i won't go there . however the man that did design on sos was pushed out at ford and went to work for john deere where he can up with the powershift
j cook (iowa)
08-25-2006 18:03:36
 Re: Why did John Deere use Fords powershift transm in reply to 730virgil, 08-25-2006 14:46:07
The bit about someone from Ford who worked on the POS SOS going over to John Deere is perhaps true. However, he did not bring any of FORD'S ideas along and get them incorporated into Deere's design---Deere already had their design.
That man's objections at Ford, which got him fired were over the unreliability of the SOS design. He couldn't persuade FORD to put more work into their design before releasing it.
When he was fired and went over to Deere, about all he was able to tell John Deere was what didn't work with the Ford design. That is not the same thing as designing Deere's powershift, from scratch, for Deere, which is what is being accused here.
John Deere's design is all John Deere and contains no features atributable to Ford.
730virgil
08-26-2006 20:54:43
 Re: Why did John Deere use Fords powershift transm in reply to j cook (iowa), 08-25-2006 18:03:36
that's about the same story i've heard . he told ford sos wasn't ready for use in tractor size of 6000 . he also told them what needed to be done to make it work . ford didn't want to spend the money and didn't like be told they were wrong . he went on vacation when he came back the tranmissions were being used when he starting raising heck and got fired . after he went to work for deere he helped refine power shift . does this agree with what you have heard ? somewhat local man knows how to fix sos work so don't need rebuilding all the time .
Gary from Muleshoe
08-25-2006 11:04:47
It not question if you could be wrong? YOU ARE DEAD WRONG. GAT SOME EDUCATION BEFORE YOU START ACCUSING JD OF THINGS YOU OBVIOUSLY KNOW NOTHING ABOUT.
j cook (iowa)
08-25-2006 08:16:43
GET ONE THING STRAIGHT! JOHN DEERE DESIGNED AND BUILT THEIR OWN POWERSHIFT ENTIRELY FROM SCRATCH/ GOT THAT? YOU MIGHT AS WELL ASK WHICH AUTOMOBILE COMPANY STOLE THEIR AUTOMATIC TRANSMISSION FROM WHOM!
Other interestingly similar products include the CASE-O-MATIC, the POWER DIRECTOR, the OVER-UNDER HYDRAUL SHIFT, and the MULTI-POWER, all vs the infamous IHC TORQUE AMPLIFIER! Nobody every accuses anyone of those companies of stealing IHC's bad idea either. Everyone always assumes that the 2 or 3 speed shifters used on those tractors is entirely different from the TA and also from each other.
Finally. there are several "bashing boards" available which encourage this sort of thing. Why not go there and stir their pots instead?
G/MAN
08-25-2006 07:52:25
You've obviously never seen the inside of a Deere 8-speed OR a Ford S-O-S, have you? I've overhauled both, and they're not even similar in construction. Want to buy some beach property in Arizona? Deere "steals patents"? That's another hoot. Deere OWNS more patents than any other ag company, and by a large margin. How many companies are building planter row units that are basically copies of the Deere units? Get a clue, and go try to stir the pot somewhere else. There's more real knowledge about Deere products on this board than you'll ever be able to deal with.
TimS
08-25-2006 07:38:02
And you are basing this on what? The fact that JD came out with a clutchless transmission? The fact that you can shift without using a clutch in itself isn't patentable.
I am certain that if Ford felt that the JD PS transmission infringed AT ALL on ANY of Ford's patents they would have been in court 40 years ago to stop JD doing so.....
Since they didn't, it pretty much proves the point that Ford WASN'T infringed on.
Then again, you would think I would know better than to bite on a baited hook somebody trolled thru.....
Haha.
No feeding the trolls!
