Wow! Gary, you haven't given much data here. Has the tractor been setting (idle) for a long time? Did it work when it was last used? Has any work been done on the tractor since it last acted normally? Or, have you just acquired the tractor and found it acting up? Does the engine seem to otherwise IDLE normally? Did the governor seem to have an excessively loud and unusual sound -- like something came loose inside? A JD Governor seldom just suddenly fails without some sign. For openers, let me assume that what you are saying -- in effect -- is that control of engine speed seems out of kilter and/or the governor appears to be failing to open the throttle butterfly (on carb) when a load is placed on the tractor. Further, lets assume the engine will fast idle! Step # 1 is to verify correctness of the Linkage Adjustment (Engine not running) -- Free up and align all linkage to remove any binding. Adjust or renew any parts causing lost motion, and disconnect throttle rod at carburetor. With hand control in full speed position (engine not running), adjust the length of the carburetor throttle rod so that the rod is 1/2 hole short from entering hole in carburetor throttle shaft lever when carburetor butterfly is in wide-open position. Reconnect throttle rod at carburetor. Be sure no cotter pin is bent in a fashion so as to hinder to & from motion of the throttle rod. Step # 2 is to verify clean fuel and clear carburetion -- (a) Place a catch basin under your carburetor and with the fuel valves open, allow a cup or so of fuel to escape. You should have a steady stream and with no particles. Observe also during the flow that fuel in the sediment bowl seems to be clear. If the fuel is old and has a foul odor, drain it out; flush your tank and lines with a half-gallon of kerosene, and then install some clean gasoline. (b) Go to the JD-H Restoration Site (listed below). When you get there, one-click on CARBURETORS over on the left side; allow time for the PDF document to come up, then go to page 7 to TESTING -- LOAD AND IDLE PATHWAYS. Read carefully, and then run these no-wrench tests on your carburetor to ensure both its IDLE and LOAD pathways are open. Step #3 If my assumption about the engine running okay is wrong so far as an apparent "air starvation" problem is concerned, try this series for TROUBLESHOOTING AIR IN-FLOW: (a) Unbolt the air intake elbow from the carburetor so that ambient air can easily flow into the front of the carburetor. If the tractor runs normally, then you have confirmed that the flow of AIR IN is the problem. (b) Assuming the engine runs OK in (a) above, drop the oil cup from the air filter, and re-attach the elbow to the carburetor. If the engine dies, the air filter mesh is clogged. If the tractor runs normally, the air filter mesh is probably okay, and the problem is likely in the stack. (c) With the engine still running from (b) above, re-attach the oil cup to the air filter being CAREFUL not to have your fingers between cup and filter. If the cup sucks up on the air filter and the engine dies -- this confirms you have a clogged air stack. DIRT DAUBERS!!! (d) If you confirm you have a clogged air stack, pull the entire assembly clear off the tractor and unbolt it. Then use a pressure washer and some soap to clean until the water flows freely and clean. The final step is to post back here with some answers to questions asked in the opening paragraph, your test results, and a description of continuing failure if its still there; or that your problems are gone! (PatB)
