620 carb adjustment
Illinois Adam
08-24-2006 19:18:25
Just bought this tractor, and Rebuilt the carb. I adjusted it just like the owners manual says, and It seems to be running a little lean.
Have any of you guys ever put bigger jets in them?
Do I need to open something more?
The original owners manual has writen in the back that the tractor was rebuilt in 1986, with a new JD block .045 over M&W pistons, and all of the other usual things. Acording to the hour meter, wich works, It has 10 hours on it since then. Is 045 enough to rejet the carb? I've adjusted valves, changed points, rotor, cap , points, plugs, and I've even checked the timing. Any suggestions?????
Chuck730DSE
08-25-2006 06:29:25
 Re: 620 carb adjustment in reply to Illinois Adam, 08-24-2006 19:18:25
The first thing to do when you are having lean out on these is to open the pet cock on the bottom of the bowl. If it had a bolt in it, replace the bolt with a new pet cock. This allows you to check the float, drain the bottom of the bowl of water, etc. You should get a small pencil size flow of steady gas for 45 seconds to a minute. If not, you have float or other issues. It can be the automatic gas shut off. It operates on oil pressure. If the bladders are ruptured, you will not get a good flow of gas. This is the cast device screwed to the bottom of the gas tank, on the left side under the hood.
The other possible issue is something blocking the outlet hole in the bottom of your tank. i have seen them where they would run good at times, and shut down at others. Found something moving around in the bottom of the tnak. Once removed, we had proper fuel flow all the time.
Just make a check list and use the process of elimination.
Once you know you have a steady and reliable fuel flow, then attack the carb. Chances are, unless the rebuild was done by one of the top shops, they did not clean out the idle passages. Some shops remove the steel balls to clean out the passages. I have done it successfully by using various sizes of torch cleaners.
You did not state if your lean out was idle or load, but it is a passage blockage somewhere if you are getting proper fuel flow.
Good luck and let us know how it comes out.
Chuck730DSE
08-25-2006 06:27:46
The first thing to do when you are having lean out on these is to open the pet cock on the bottom of the bowl. If it had a bolt in it, replace the bolt with a new pet cock. This allows you to check the float, drain the bottom of the bowl of water, etc. You should get a small pencil size flow of steady gas for 45 seconds to a minute. If not, you have float or other issues. It can be the automatic gas shut off. It operates on oil pressure. If the bladders are ruptured, you will not get a good flow of gas. This is the cast device at your fuel cut off, screwed to the bottom of the gas tank, on the left side under the hood.
Illinois Adam
08-25-2006 19:00:59
 Re: 620 carb adjustment in reply to Chuck730DSE, 08-25-2006 06:27:46
I haven't rebuilt a lot of carbs, but what steel balls are you talking about. The flow out of the tank is good. I took the carb off today and have it soaking again. I will try anything to make it run like it should.
Carl NY
08-25-2006 02:29:45
The .045 over pistons should not require rejetting of the carb. What are the symptoms you have when you say it is running lean? You may have some passages in the carb that are not thoroughly cleaned out. Try opening the idle needle adjusters. Also check the main load needle as they often need replacement after years of service. I bored one out .125 over & it ran OK with the stock carb. The M&W pistons are probably high compression and the tractor may be running warmer now, so you may have to experiment with timing also. You need a catalog of parts from Roberts Carburetor in Spencer, Iowa. Phone # 712-262-5311. E-mail or call me @ 315-945-7138 if you need more info.
Illinois Adam
08-25-2006 18:55:55
 Re: 620 carb adjustment in reply to Carl NY, 08-25-2006 02:29:45
It's almost like its running on one cylinder.
When it idles it is a nice slow put put put. wide open it backfires, like it needs more fuel. When it's idling, and I push the throttle open, It takes a little time to get up to high rpms.
Carl NY
08-26-2006 05:36:35
 Re: 620 carb adjustment in reply to Illinois Adam, 08-25-2006 18:55:55
This sounds more like one or more of the small passages are plugged up. You may have to let it soak in a good cleaning solution two or three times. Also find some thin wire, my wife had some she used for crafts, and I ran that thru some of the passages after removeing some of the plugs. Roberts has some long drill bits that I also use. Turn them by hand only.
