2010 Injectior pump issue
EMG
08-24-2006 06:49:50
My 2010 industrial was running fine and then just quit with no warning. Fuel is making it to the injector pump but when I removed the injector lines fuel was just barely coming out when I cranked the engine. I played around for a while removing fittings and checking for blockages and I got it to re-fire for about 30 seconds then it died again. Are there any things to look for that I might be able to address or is it rebuild time? Is a rebuild possible at home or is this a dealer only thing?
Thanks!
Bob
08-24-2006 07:13:15
 Re: 2010 Injectior pump issue in reply to EMG, 08-24-2006 06:49:50
Likely, the fuel return fitting/housing pressure regulator valve in the pump's top (side) cover has been clogged by chunks of broken up dark plastic from the governor damper ring.
Disconnect the return line, remove the complete fitting/valve, and check for the chunks of crud. If present, you've found the problem.
There is a spring-loaded glass ball in there, and, being carefull not to break it, you can dig out the crud, and blow the remainder out with compressed air.
The tractor should start and run, but you will need to find the time and money to get the IP OH'ed, as once enough of the plastic ring breaks up, there is no longer and cushion between 2 metal parts in the governor, and they begin to vibrate together and wear sloughing off metal filings into the pump.
jdemaris
08-24-2006 19:11:25
 Re: 2010 Injectior pump issue in reply to Bob, 08-24-2006 07:13:15
Most of the pumps used on the 2010s did not have the housing pressure regulator (with spring and ball). Just a fitting with a vent-wire.
EMG
08-24-2006 08:26:09
Thanks for the info!
Should I dig the crud out thought the return fitting hole or am I supposed to remove the side cover?
Bob
08-24-2006 10:26:53
 Re: 2010 Injectior pump issue in reply to EMG, 08-24-2006 08:26:09
The crud be IN the fitting/valve, which you will have in your hand, once it"s unscrewed from the pump.
Bob
08-24-2006 10:27:41
 Correction in reply to Bob, 08-24-2006 10:26:53
The crud WILL be IN the fitting/valve, which you will have in your hand, once it"s unscrewed from the pump.
