70 diesel engine blowing pony oil out of pony vent
Mike W J
08-23-2006 20:15:48
Where is the big engine vented at it runs fine but blows almost all of the pony oil out of its vent pipe This tractor had not been run since 1978 we replaced govener bearings and cleaned it out best we could without complete teardown. THANKS MIKE
buickanddeere
08-24-2006 15:57:13
 Re: 70 diesel engine blowing pony oil out of pony in reply to Mike W J, 08-23-2006 20:15:48
Isn"t these a ventilation port drilled through the head from the crankcase into the intake manifold?
Blksmok
08-24-2006 05:14:32
Mike..the diesel engine is vented up through the front timing gear cover of the pony engine, into the pony engine block and then out through the pony engine air cleaner. Where are you seeing the oil that's blown out???
Mike W J
08-26-2006 06:32:57
 Re: 70 diesel engine blowing pony oil out of pony in reply to Blksmok, 08-24-2006 05:14:32
The oil from the pony engineis being pushed out the pony vent tube that is hooked to the side of the pony air cleaner I unhooked it from the air cleaner to see if that was why the pony carb and intake were filling with oil when the big engine was run . With the vent tube unhooked it sprays oil not just fumes but almost all of the pony oil out in about 15 minutes. Thanks
F-I-T
08-24-2006 08:31:01
And the tell-tale sign is normally that the blown out oil is black like the diesel, not clean like the pony aircleaner oil.
mjbrown
08-24-2006 06:17:23
I thought those engines were supposed to suck in through that air cleaner into the intake?
Blksmok
08-24-2006 06:49:09
 Re: 70 diesel engine blowing pony oil out of pony in reply to mjbrown, 08-24-2006 06:17:23
MJBrown....when the pony engine is running air is sucked through the air cleaner. There is a small vent pipe behind the right cylinder head that connects the pony engine block to the air cleaner and that's where the diesel engine crankcase vapors eventually vent.
