2010 hydraulics bypass
Dave / Believer
08-23-2006 19:28:26
I have a 1962 gas 2010 (yes, I am the one that bought one! - sigh at least it was used and not new) that is building excessive pressure in the hydraulic system. It was pushing the seal out of the end of the remote valve so I bypassed the remote (removed the valve body from the pedestal and reinstalled the cap which has a bypass galley in it) but it is still pushing hydraulic oil out between the cap and the pedestal. All I do with it is bushhog a six acre field and a two acre fenced pasture here at home so I do not need anything hydraulic, I have the three point chained at the correct height so I do not need it except to attach the bushhog, I have not had a need to raise it for a couple years. It does not have power steering. Fixing it seems futile, nobody seems to know much about diagnostics. I had the idea to pull the hydraulic pump front cover and remove the drive gear from the hydraulic pump to disable the hydraulics altogether but am not sure if the hydraulic pump has anything to do with lubrication in the transmission. It runs like new, starts quickly and no smoke so I hate to just throw it away. I was told I should be able to get $2500 or so for it as is but think that is optimistic.
Can anyone tell me if disabling the hydraulics as described would create problems in other systems?
Thanks -- Dave / Believer45
Bob
08-24-2006 01:40:31
 Re: 2010 hydraulics bypass in reply to Dave / Believer45, 08-23-2006 19:28:26
I'm not following your description of the leakage problem.
However, if it doesn't have power steering, and you want to shut down the hydraulic pump, simply flip the lever, key # 27, protruding from the bellhousing!
Third Party Image
Dave / Believer45
08-24-2006 15:23:17
 Re: 2010 hydraulics bypass in reply to Bob, 08-24-2006 01:40:31
Evidently the hydraulic system is building too much internal pressure. The spool seal on the remote control valve pushed itself out of the valve body so I thought to simply bypass the remotes as I do not use them for anything. This did not work, hydraulic oil still forces itself out through the gasket and O rings between the remote valve pedestal and the top cover to the valve which I reinstalled on the pedestal to create the bypass circuit. I do not use the three point hitch lift or anything hydraulic at all so I wanted to just eliminate the system since the 2010 is not a very salable unit and I could not get much for it toward a replacement.
I will check about the lever you describe, thank you VERY much for the heads up.
As you can tell, I am pretty much a newbie at this.
Dave / Believer45
Bob
08-24-2006 15:50:10
 Re: 2010 hydraulics bypass in reply to Dave / Believer45, 08-24-2006 15:23:17
The system is "open center", and oil should move freely through the valves and reservoir, unless one of the valves (remote, or in the 3-point) is not returning to center.
I wish I could help you more over the 'net, but that hydraulic system was quirky even for the dealership mechanics, in it's day.
If you intend to troubleshoot it, I would suggest getting a factory shop manual from Deere Techpubs, @ 1-800-522-7448. Most likely, besides detailed troubleshooting instructions, it will have color charts of the hydraulic system flows.
To be more correct about the pump drive disconnect, you move lever #30, which is then latched in the "disconnect" position by lever #27.
