1940 B backfires
Gary from Mules
08-23-2006 19:04:28
I started my be for the first time in about a week tonight and it wanted to back fire now and then. I readjusted the carb and dried out the mag and it went away after letting it run for about 30 minutes at high idle. Will moisture in the mag cause it to back fire. Just looking for some good advice as to what to look out for. We had about 4 inches of rain this week and it has to set out in the weather, exhaust was covered but never thought to cover breather stack. It did have water in the oil bath, but I cleaned it before I started it.
John T
08-23-2006 19:51:23
 Re: 1940 B backfires in reply to Gary from Muleshoe, 08-23-2006 19:04:28
Gary, Among other possible causes YES moisture in a Mag can indeed cause backfiring. What happens is the spark may jump around n arc across a moisture conductive path and say jump over to the wrong cap terminal and fire a plug at a time other then when its supposed to. Its good to keep the mags vents open n clean so ozone or moisture can exit. Timing and carbs and valve lash or sticking might also cause a backfire.
John T
