HP rating....
farmallman
08-23-2006 17:50:07
so, my G is rated at 34 hp drawbar...how many furrow plow can that pull? In the operators manual it shows it w/ a 3-furrow plow for aligning, but could it pull a 3 furrow plow? where i live the ground is fairly (somewhat heavy) clay. or would I be better off w/ a 2 furrow?
thanks
and what is ur experience? what does a better job?
buickanddeere
08-23-2006 17:57:24
 Re: HP rating.... in reply to farmallman, 08-23-2006 17:50:07
1 to 4 depending on the soil, moisture, tires, plough brand, furrow width,depend son who adjusted the set up and etc.
B-maniac
08-23-2006 19:50:50
 Re: HP rating.... in reply to buickanddeere, 08-23-2006 17:57:24
I believe that hp rating is for fuel and not gas.I don't think they made a gas only "G". So if you are running gas it will be up a couple hp over fact. rating. An "A" will pull 2/16s anywhere in plow gear. I don't think your "G" would have any problem with 3/14s and maybe even 3/16s. If it does,you have one sick "G". Back in the day,we pulled 3/14s in 3rd with an Oliver Super 55,rated at 38 hp. I can tell you for a fact,a "G" JD on gas will out pull a Super 55 any day of the week! There's a lot more involved than just a figure of 38 hp.
farmallman
08-24-2006 06:02:14
 Re: HP rating.... in reply to B-maniac, 08-23-2006 19:50:50
I understand that there is more to it than hp, but that is a good indication of what it can do. what gear would be the best to pull in? 2nd? 3rd?
buickanddeere
08-25-2006 19:48:57
 Re: HP rating.... in reply to farmallman, 08-24-2006 06:02:14
Heavy draft loads with a 2WD & bias ply tires. Are best pulle dat 3 to 5 MPH. That would be 2nd & 3rd if memory serves correctly. Tire size will vary ground speed. Soil type is everything. Dry clay here. It will spinout a 5000lb tractor easily with just a mounted 2x14" plough.
Brendon
08-23-2006 20:42:45
If you are refering to a late model A ('47 or later), I would imagine that they were rated for a 3-14 as my '50 B was rated for a 2-14 plow according to the manual. I have seen both combinations at work in very heavy gumbo ground at our Goessel, KS show grounds. Early models of the A and B were rated for one bottom less. I would think too that a G could easily handle a 3-16 plow in most any ground fit for farming.
