2010 Will not Start
Scott Moore
08-23-2006 06:54:23
Hello All
Need your help if you can. I have a 63 JD 2010 gasoline that just will not start. Cranks over but no firing. THis is what I have done thus far with no success.
1. Checked to make sure gas was flowing. It is.
2. Changed the points, condensor and rotor. 3. Checked the wire from the distributor cap to the coil. Looks good.
4. Unplugged wire from the distributor side going to the coil to see if I was getting any spark coming from the coil. I AM NOT!!
5. Changed the coil. No success! Still no spark.
So that is where I am now. Was going to start tracing wires to make sure everything is good, but I figured I would post a message to see if anyone has any other ideas or recommendations. Appreciate any help all of you can give.
Scott
jdemaris
08-23-2006 18:26:35
 Re: 2010 Will not Start in reply to Scott Moore, 08-23-2006 06:54:23
Check the basics before you try to figure out the 2010 wiring. It's simple system. Make sure there is power getting to the primary terminal of the coil (Negative terminal if you're using positive ground). The other primary terminal goes to your points. Make sure it's not grounded when the points are open and make sure it IS grounded when the points close. If you have a ballast resistor problem, you won't have proper power getting to the Neg. primary terminal. 2010s originally had the ballast resistor, and bypass, built into the ignition switch. Deere sold update kits for it later (starting around 1970)to install a newer switch and a separate wire-wound resistor. Most of the time, such "no spark" problems are from either a grounded point's circuit, or a set of points that are oxidized and not making proper contact - i.e. high resistance. I've had many, new out of the box that would not work until polished.
billde
08-23-2006 17:38:19
Sounds like your ballast resistor is bad.
John T
08-23-2006 13:20:55
Scott, anything after the 2 bangers is not my area but I will post my standard troubleshootign procedure for coil ignition systems and you can see if it helps. Im not sure if that tractor used a link of resistor wire or a link of thermistor wire (heat sensitive variable resistor) or a discrete external ballast resistor (dont think so) after the ignition switch and ahead of the coil, cuz if it has any of those devices and if they are bad n opened up the coil wont have voltage on its input terminal thus no spark. Sooo when I discuss Ballast Resistor below be aware it could just be a link of resistor wire or a link of thermistor wire versus the bare discrete ballast resistor like the older tractors used. Regardless what it used or even if it didnt use any YOU GOTTA HAVE VOLTAGE TO THE COIL WHEN THE SWITCH IS ON OR ELSE NO TICKY NO LAUNDRY N NO FIRE LOL
TROUBLESHOOTING A BATTERY POWERED EXTERNAL COIL TYPE IGNITION SYSTEM:
PRELIMINARY CHECKS:
(A) To see if it happens to be a cap n rotor problem and to see if at least the coil is firing, remove the coil wire from the distributor (leave coil end intact) and place its bare end to within 1/8 inch from tractor iron, turn her on n crank her over, and see if she jumps that gap with a good visible blue spark????? If so but the plug wire ends (from wire end to 1/8 inch to frame) or the plugs themselves don�t fire, its a cap n rotor or plug wire problem. If the coil wire isnt even sparking, see below.
(B) Next open the cap and see that the points are gapped correct and indeed opening and closing as the engine is cranked and the distributor shaft rotates and MAKE SURE THEY ARE NOT BURNED OR PITTED OR CARBONED UP BADLY !!!!! !!!!! If so, running a point file between them to clean them up might make her run again HOWEVER that�s only a temporary cure, so if that cleaning makes her spark, INSTALL N GAP NEW POINTS. In the event they appear good but only gray oxide coated, non abrasively clean/buff/polish them using say a dollar bill or shop cloth etc. and see what happens.
MORE TROUBLESHOOTING IF ALL THE ABOVE STILL FAILS TO MAKE HER SPARK
1) THE VERY FIRST THING YOU GOTTA HAVE is voltage to be present on the coils high supply (NOT to distributor) terminal when you turn the Ignition switch ON. If not she cant ever fire, but in the event the ignition switch or circuit/wire down to the coil or any Ballast Resistor is bad or open, you can HOT WIRE it by jumping a hot ungrounded battery voltage source to the coils high input supply (NOT to distributor) side n see if she runs then???? If she fires hot wired, you could have a bad ignition switch ((That can happen, when Ignition is on, the switches IGN terminal must turn hot)),,,,, ,or an open Ballast (if it has one) or a bad/open wire from switch to coil.
If the switch is good, if you turn the ignition switch on and place a test lamp on the coils high (NOT to distributor) terminal SHE MUST LIGHT UP. If not again, look for an open Ballast Resistor (if it has one, it should read around 1.25 to 2 ohms across its terminals) or bad/open wires from the switches IGN output down to the Ballast (if it has one) and distributor.
2a) When the Ignition switch is turned on, voltage should appear on the coils high input side. That would be 6 volts on a straight 6 volt system or 12 volts on a 12 volt non external ballasted system, or around 6 volts on a 12 volt system that used a 6 volt coil plus an external Ballast Resistor and the coil is good and the points are closed and they and ALL wiring is good.
2b) To insure the coils low voltage primary winding is not bad/open, use an ohmmeter and measure its DC resistance between its lil + and -terminals. If its an open circuit (no continuity) its bad/open and will NOT work. It should measure around 1.25 to 2 ohms or so if its a 6 volt coil and maybe 2.5 to 3.5 if its a 12 volt internally ballasted coil. NOTE CAUTION have all leads and any voltage source DISCONNECTED FROM the coil for this simple primary winding continuity test. 3) Next, place your voltmeter or test lamp over on the coils other low to distributor terminal side, turn her on and crank the engine over.
4) A test lamp there should flash ON (when points are open) and OFF (when points are closed) as the engine is cranked slowly.
5a) If the lamp never comes on there, the coils primary is bad/open,,,,, ,,,,or the points are never opening,,,,, ,,,or theres a shorted/bad condensor (remove its lead to points and see if lamp comes on, if so, bad shorted condensor or its wiring),,,,, ,,or the points wire is shorted,,,,, ,,or the distributors side pass thru stud is grounded (use ohm meter to test that),,,,, ,,,or the points may have a shorted spring.
5b) If the lamp never goes off as engines cranked, the points are not closing or are bad,,,,, ,,or the wire or circuit is missing from the distributor to the points,,,,,or the distributors not well grounded to the tractor.
She cant fire the coil unless its low side is getting a conductive ground return path via closed points and then the circuit is open when the points open.
Be sure the condensor or its wiring is NOT shorted out and see if the lite comes on (when points open) with the condensor disconnected. If removing the condensor makes her spark, replace the condensor.
SUMMARY
Be sure the points are closing fully and open on high cam and ARE NOT BURNED OR PITTED OR CARBONED UP BADLY,,,,, ,theres voltage present on distributors high side at all times when ignitions on (or its a bad switch or open ballast or bad wiring to col),,,,, ,voltage on coils low side flashes on and off as distributor is cranked,,,,, ,,,condensors not bad/shorted,,,,, ,,no shorts in wires to points and no shorts in pass thru side out distributor stud,,,,, ,,coil has continuituy.
You may luck out n just need a new set of points. If the coil wire fires (see above) and the plug wire ends to 1/8 from frame but NOT the plugs, they are baddddd ddddd . Check them BOTH.
Good Luck n God Bless, post back any questions and your findings and any questions.
John T Nordhoff in Indiana
Scott Moore
08-23-2006 08:48:46
Thank you very much. It will take me some time to get back to the tractor and I will respond back within a week. Appreciate your help!!
Bob
08-23-2006 07:40:04
Start simple.
Take a test light, and check for voltage on the coil terminal fed by the ignition switch with the key "ON". It should light.
The other coil terminal is connected to the distributor's breaker points and condensor.
With the key still "ON", check that terminal with the test light.
If the breaker points are "open", the test light should light.
If the breaker points are "closed", the test light should NOT light.
If you then crank the engine with the starter, the light should flash "on"and "off" rapidly, as the points open and close.
Post back with the results of these simple tests.
(These ignition systems MAY have a ballast resistor on the ignition switch, or in-line somewhere, depending upon what ignition system it has (Delco or Prestolite), or what someone has done to it in the last 40+ years, and this COULD be a source of problems, if no power to the coil.)
