This problem has been beat around quite a bit lately, but I am at a loss to guide you to the threads you need, so here goes! I assume you are saying the engine is being starved for air intake. If this is the case the blockage can be in two places, but depending on the prevalence of dirt daubers in your area, I tend to lean toward those critters having built a dirt castle in your air stack. TROUBLESHOOTING: (1) Unbolt the air intake elbow from the carburetor so that ambient air can easily flow into the front of the carburetor. If the tractor runs normally, then you have confirmed that the flow of AIR IN is the problem. (2) Assuming the engine runs OK in (1) above, drop the oil cup from the air filter, and re-attach the elbow to the carburetor. If the engine dies, the air filter mesh is clogged. If the tractor runs normally, the air filter mesh is probably okay, and the problem is likely in the stack. (3) With the engine still running from (2) above, re-attach the oil cup to the air filter being CAREFUL not to have your fingers between cup and filter. If the cup sucks up on the air filter and the engine dies -- this confirms you have a clogged air stack. DIRT DAUBERS!!! Please post back with the results of these test. We like to know if we hit it. (PatB)
