JD 2010 Hydraulics question
Double M
08-22-2006 13:25:34
Recently got a "63 model 2010 with an ARPS front end loader. I have worked the loader pretty hard for several days. A problem has since cropped up. It starts out working fine but then hydraulic pressure starts pulsing after about 15 minutes of use. I feel it in the power steering and the loader operates poorly. It seems to have plenty of oil in it. Any ideas?
Double M
08-23-2006 12:48:48
 Re: JD 2010 Hydraulics question in reply to Double M, 08-22-2006 13:25:34
Thanks, I"ll try cleaning the filter.
chrisfromsolitude
08-22-2006 15:38:08
The filter is more than likely the problem. I believe all of your hydraulic oil is filtered on those tractors so if the filter gets plugged enough you will lose steering too.
KEH
08-22-2006 14:26:10
Try changing the hydraulic oil and the steel mesh filter located at the bottom right side of the transmission case. The filter can be washed out and blown out for a couple of oil changes in the future but will eventually have to be replaced again. I'm assuming you don't know when the oil was last changed.
KEH
