1020 Diesel starving for fuel
Frank in WV
08-22-2006 12:43:39
I have a 1020 Diesel that is driving me crazy, if you take it out on the road it acts like it runs out of fuel and dies. This occurs up hill or down hill. You can start it right back up after it quits running and it will run fine for a while. I can run it at full throttle not moving and it runs fine, but take it out on the open road and it quits. I have changed the fuel filter and this has not helped, I did get a little bit of black specks in the bottom of the sediment bowl. Do I have algae in the fuel? Plugged line? Bad diesel? I plan to drain the tank and have put some conditioner in the fuel already in tank. Any other suggestions?
jdemaris
08-22-2006 17:13:44
 Re: 1020 Diesel starving for fuel in reply to Frank in WV, 08-22-2006 12:43:39
What F-I-T told you is a good place to start. If the fitting in the tank is getting plugged, trying adding a small strainer-screen to it that stands up off the bottom of the tank. Also, keep in mind, that when the plasic weight-retainer falls apart inside the injection-pump,it will have just about the same symptoms. It will run good, then peter out and quit, and then start right up again.
machinery-man
08-22-2006 13:15:42
I also have a 1020 but haven"t had this problem, but it does sound like fuel starving. Is there an air vent on the fuel cap? Also if you could hook up a fuel supply independant of the main tank. As I recall the supply line is on the side, hook a small tank you could strap in front area and see is it does the same...if it runs okay you know its the fuel line. I"ve had the fuel line out, is on the sender plate and it may have a screen....check all this for blockage. But if it did the same with the auxillary supply it would have to be in filters on lines on tractor.
F-I-T
08-22-2006 13:06:52
I think you might have debris moving around in the bottom of the tank that might intermittently move over the top of the out port causing low flow. I'd remove the bottom fitting to drain and shake the tractor while it empties. See if you can interupt the flow by sloshing. When dry, look down the top using a flashlight and see if there is flotsam in the bottom.
It's the cheapest thing to try first method of troubleshooting.
Frank
Frank in WV
08-23-2006 08:25:09
 Re: 1020 Diesel starving for fuel in reply to F-I-T, 08-22-2006 13:06:52
Thanks to all. I will try and put a flashlight down to see inside. I will be purchasing some algae clean and a few new filters to have on hand. The shape of the tank makes it difficult to see down inside. Thanks for the help.
F-I-T
08-23-2006 09:59:24
 Re: 1020 Diesel starving for fuel in reply to Frank in WV, 08-23-2006 08:25:09
third party image
A while back I removed the lens assembly from a cheapie usb camera, put it on a stick with a small lamp and now using my laptop, I can look into tight areas. Sort of a "Poor Man's Borescope".
Frank in WV
08-23-2006 11:24:02
 Re: 1020 Diesel starving for fuel in reply to F-I-T, 08-23-2006 09:59:24
Frank, you never cease to amaze me!!! Nice contraption. I hate to ask but what is the rental price on this item and do you have a patent for it yet???!!! I plan to put the small flashlight down in along with a mirror on a handle to try and see in there. Probably will end up pulling the tank, I'm a little afraid of trying to take the whole valve assembly loose from bottom of tank, hard to tell how tight it is in there. Like you said probably a small piece of rust or something else plugging the suction hole till tractor stalls from lack of fuel, then it releases itself when I open the vent on fuel filter or just from lack of suction from not running.
