JD 420
Arthur
08-22-2006 06:44:09
I found a guy in the next town over that has a portable boaring machine...Talked to him on the phone this morning, and he said you have to take the block off of the machineto do it....???if you have to split thge tractor, what good does a portable boaring machine do??? I think he just doesn't want the work....Maybe I should offer to buy it from him, as I am a machinist....I'll figure out a way to get that thing to do what I want it to do. Just ranting.....
Hayfarmer
08-22-2006 07:02:30
 Re: JD 420 in reply to Arthur, 08-22-2006 06:44:09
I think I would want to split it to bore it out. For one thing all the grindings are gonna end up on the crank. These tractors are easy to split and if it needs to be bored it probably needs main bearings and seals and the works. If you hand a heavy blade or counter weight on the back it will balance. If I were going to go the the expense of boreing it and getting enw pistons and all I would go all the way and clean up block, check crank etc.
