The 1010s and 2010s have nothing in common with the 1020 or 2020 type tractors. In regard to the 2020 replacing the 1020, I don't think so - we sold both at the same time. The 1020 (ag) or 300 (industrial) were basically the same tractors as the German series 820 and 830. In general - from what I experienced from working on them new and used, a few general observations. The 1010s and 2010s were all four cylinder engines. 1010 gas engine was just about the same size as the older, two-cylinder 420. 1010 was 115 cubic inches, and the 420 was 113 cubic inches. In my experience, the 1010 was over-rated at 36 - 38 PTO horsepower. I tested many on the dyno and never found one that matched that claim. The 1020 tractor was basically the same as the Manheim, Germany built 820 and 830 tractor. The differeces I've observed are : The German tractors were all diesel - no gas engines, and the hydraulic systems were different than the 1020s or 300s. They had smaller pumps and also used open-center hydraulics. The options available also differed in regard to PTOs, hi-lo, reversers, etc. The 1020s were almost identical to the 300s except: Some sheet metal was heavier on the 300s, and many 300s have larger hydraulic pumps. The 1020s use the little German pump, whereas many 300s have the large, 2.4 cubic inch U.S. built pump. 1020s, 300s, were available with gas or diesel three cylinder engines and also manual steering, power steering, hydraulic reverser or hi-low, ground driven, clutch driven, or independent PTO. 1520 also came with a three cylinder engine but slightly larger. 2020s were sold at the same time as the 1020s, but used the four cylinder engine with balancing shafts, also used in the 450 crawlers. 1010 - 1960 - 1965, used a 115 c.i. gas or a 144 c.i. diesel. Rated at 36-38 PTO horse. 2010 - 1960 - 1965, used a 144 c.i. gas or a 165 c.i. diesel. Rated at 47 PTO horse. 1020 was made from 1965 to 1973 and was 38 horse at the PTO. Used a 135 c.i. gas or a 152 c.i. diesel. 2020 was made 1965 to 1971 and was 59 PTO horse. Used a 180 c.i. gas or a 202 c.i. diesel. 1520 - 1968 - 1972 with 46 PTO horse. Diesel engine - 164 c.i. 1530 followed from 1973 - 1979. 820 was made 1968 to 1973 and had same engine as the 1020, but was only rated 31 PTO horsepower. Used a 152 c.i. diesel - same engine as used in the 350 crawlers. 830 was maded 1973 - 75, same engine, but rated at 35 PTO horsepower. The 2150, made from 1983 - 1986 as some similarites to the 1020 type tractors and still uses a three cylinder engine - but 179 c.i. and 46 PTO horsepower. This basic engine is used as a replacement in older machines including 350 and 400 crawlers.
