4020 steering problem
wscott
08-21-2006 18:07:46
my '63 4020 lost steering,and the steering wheel will turn very easily left or right,never locking out.i bled the system using the jd service manual method,but it had no air in it. it pumped out alot of oil when turning right,but almost none when turned to the left. anyone been down this road before? thanks.
Pat P
08-23-2006 21:57:01
 Re: 4020 steering problem in reply to wscott, 08-21-2006 18:07:46
Yes I did, but this doesn't sound like what happened to you. Had oil sprayed all over under the hood, but with everything wet, I couldn't pin point the source. Hydraulic lines goes from the steering column over the engine and radiator before going down to the steering box. Mine had been rubbing on the radiator until it finally blew. Couldn't see it with the engine off since it was under the tube. However...with the engine on, had a nice oil geyser. Wasn't hard to find after that. A little brazing fixed it. I imagine if the other tube blew, I would have steered to the left and not the right.
Even if this isn't what happened to you, I recommend wrapping the steering lines as they pass over the radiator unless you have something that guarantees they can't rub. I used some excess fuel hose.
wscott
08-24-2006 19:51:50
 Re: 4020 steering problem in reply to Pat P, 08-23-2006 21:57:01
thanks patp. my tractors previous owner must have had the same trouble,because 1 of the lines has been brazed and covered w/ hose like yours. i'm not leaking oil,so i suspect my trouble is in the steering tower.thanks again. looks like its time to start pullin' the dash off!
