ANother Problem HELP repair john deere 709 brush h
Vicky Mendoza
08-21-2006 09:54:11
Thanks Guys!!!! He finally got it.He was doing everything right, I guess it was just stuck. He has it back together now and it works but it starts to smoke after a bit and he tightens it more. What is making it do this? HELPPPPP its time to mow down the corn.
Thanks again
Vicky
Vicky Mendoza
08-22-2006 07:14:41
 Re: ANother Problem HELP repair john deere 709 bru in reply to Vicky Mendoza, 08-21-2006 09:54:11
Please
Glen in TX
08-22-2006 09:04:24
 Re: ANother Problem HELP repair john deere 709 bru in reply to Vicky Mendoza, 08-22-2006 07:14:41
He may just need to tighten the clutch more or maybe going too fast overloading it making it slip ? I've seen the slip clutch plates or if it has splines sometimes being too worn and rusted to work with new clutch discs sometimes and just need more new parts or a complete new slip clutch. Whatever he does don't be drilling thru the clutch bolting it solid as that will just twist the drive shaft off instead of letting it slip. Might also check to see if a TISCO ( woodsonline.com ) or A&I dealer has aftermarket clutch assembly or parts for less besides JD.
Vicky Mendoza
08-22-2006 21:55:34
 Re: ANother Problem HELP repair john deere 709 bru in reply to Glen in TX, 08-22-2006 09:04:24
Ok Thanks Bunches!!!!! ! I'll pass the word on!! You have been such a big help.(((HUG))) Thanks again!
Vicky
