JD 300 backhoe sump screen problem
Mark Thomas
08-21-2006 09:17:22
Bought this unit a few months ago, and the hydraulics were very slow. Haven't had much time to work on it. Started this past weekend, changing all the fluids, filters, etc. Went to check/ clean trany sump screen, and it won't come out more than 2-3 inches. It was covered in dark brown goow. Acts like it is hanging up on something inside. Worked on trying to get that screen out for 45 minutes, but no can do.
If I really force it, and the screen tears, I'm worried it will tear the rear steel rings off and those will be stuck inside the trany. Any help, tricks or suggestions ?
Mark Thomas
08-22-2006 08:55:38
 Re: JD 300 backhoe sump screen problem in reply to Mark Thomas, 08-21-2006 09:17:22
Thanks Jonathan,
I guess I will give it a try. I already bought a new metal screen. Is dumping diesel down through the trany a good idea to clean out junk? I thought the diesel residual would contaminate the new oil?
Jonathan in MA
08-22-2006 12:12:41
 Re: JD 300 backhoe sump screen problem in reply to Mark Thomas, 08-22-2006 08:55:38
If you let it drain from the suction tube port you'll drain 99% of the fuel out ... that remaining 1 % will dilute in the oil... no worries... don't forget to replace both filters also... also check out the debris that comes out... look for brake facing material and/or metal grindings... hopefully its just old cylinder packing material and pine needles...
Jonathan in MA
08-21-2006 15:04:20
... maybe you have it out by now... but.. assuming you removed the return filter canister assembly out of your way, I'd just get on it with a pair of pliers and try and squeaze it smaller as you pry it out. It will end its usefull life, but may be worth it . I believe the metal ones have the ends soldered on so it shouldnt come apart.. just probably lots of debris on it.. You can get a new one of the same style or theres also a plastic version too... after its out, dump some diesel fuel thru the transmission to flush out what may be left on the bottom...
