Fixing 4010 axle seal and bearing...
TimS
08-21-2006 07:03:53
I need to change the seal and bearings on my 4010, how should I go about getting the wheel off?
Jack up that side of the rear axle and take the rim off the center piece by loosening the clamps? Or take the center and rim and tire off all in one piece?
Any advice is appreciated, as you can tell this is my first experience working on a 'big' tractor.
John179
08-22-2006 09:33:21
 Re: Fixing 4010 axle seal and bearing... in reply to TimS, 08-21-2006 07:03:53
I would use a bottle jack to lift tractor off the ground then use your blocks to support the tractor because you just cant trust your jack. Also do you have fluid in the wheel? If you do drain it out or get a good strong loader or forklift to lift the wheel. Also the axle hoseing is not as heavy as some would think. Dont get me wrong its heavy but your over head hoist will do fine as long as its a 1 ton hoist wouldn't want to over stress it.
Richard 55
08-21-2006 19:23:33
Tim S
Have fun!!! My wife and I just replaced the ones on our 4010 about a month ago. We used a bottle jack then blocket it up.Removed the wheel and tire as a unit because it looked like it would be a pain centering the rim back on the cast center.The worst part was getting the cast center off the axle,because it was stuck solid and the gear that drives the wheel off had the teeth knocked off before i bought the tractor.Getting the wedge to come loose was a pain in the you know what.Broke one of them in the process.If you just replace the seal you can do it yourself,but if you want to replace the bearing then you may want to remove the final drive and have JD or some one replace them for you.The bearings have to be pressed off the axle shaft.I replaced the inner and outer bearings on one side while i had it apart.They charged me I think 450.00 for parts and labor and I took the final drive to them.If I had it to do again I would not have replace the bearings because they were not that bad,Just the seals were out.The previous owner had let plastic twine wrap around the axles and left it there,pushing the seals out.
MAT JD
08-21-2006 12:56:29
We did our 4020 and 4230 it's not fun. we couldn't get the wheel off. so we wraped a chain around the tire.That worked good. If you have a question e-mail me
John179
08-21-2006 08:02:03
Take the whole wheel off in one piece. it's much eazier to use the gear in the cast to walk it off the axle. Becasue if you remove the rim from the cast center it's a pain in the butt to get rim centered when remounting. it is possible but time consuming. if the cast is froze on the axle apply alot of heat to cast keep constant presure of the gear mechanism and beat end of axle with a larg sledge hammer.
TimS
08-21-2006 10:36:47
 Re: Fixing 4010 axle seal and bearing... in reply to John179, 08-21-2006 08:02:03
I have another question, what do you folks use to jack up the rear axle? Floor jack, bottle jack, high lift ratched style jack?
I have a bunch of 4x4 and 4x6 and 6x6 post sections to use for cribbing once I get the tractor jacked up, I don't think my little car jack stands will be much use.
What method do you use to dismount and remount the wheel? Run a strap from the wheel up to a chain hoist to support it as it comes off and goes back on?
I was thinking I would need to use the chain hoist on that axle housing as I unbolt it, it looks pretty heavy all by itself.
