JD 400 Backhoe
Jych4
08-21-2006 04:51:09
Plungers leak from the hydraulic control block were all the handles are, sorry for the terminology but i dont know much about this stuff. This machine is old probably early 1970, my question is how can i get the plungers out to change the seals?
Thanks James
fiddler_again
08-21-2006 07:27:06
 Re: JD 400 Backhoe in reply to Jych4, 08-21-2006 04:51:09
I had a JD motor grader that was about that age and had a similar block where the controls were. To remove plungers on that machine, you would remove the plug at the bottom, and then (with the engine running) bump the control lever for that plunger while holding a cup or something under the opening (where the plug was removed). The hydrolic pressure would just pop the plunger right out. Install the new seals and re-insert.
I"m not sure that your machine is the same, but maybe this helps.
Jych4
08-21-2006 07:50:29
 Re: JD 400 Backhoe in reply to fiddler_again, 08-21-2006 07:27:06
Thanks for the imformation, i seen the plugs underneath the pistons i will give it a try.
A couple of the pistons do not hane a plug it is solid.
Thanks James
