4 cylinder power unit questions
wilson
08-20-2006 18:14:42
What is the cubic inch displacment of the 4 cylinder power units as used on 30 combines and some hay balers??? What is the goverened rpm??? Is this the same basic motor used in the 1010 tractor??? Any idea of horsepower??? Thanks
wilson
08-21-2006 16:28:30
 Re: 4 cylinder power unit questions in reply to wilson, 08-20-2006 18:14:42
Hey thanks guys Would any of your books on manuels give the goverened RPM for running the combine?????
Glen in TX
08-20-2006 21:34:10
If you have a number off engine can probably get a manual for it from JD publications. Several power units listed in publications catalogs but you need a model number of some type.
WV2cyl
08-21-2006 02:32:22
 Re: 4 cylinder power unit questions in reply to Glen in TX, 08-20-2006 21:34:10
It is a HA-92 John Deere engine
WV2cyl
08-20-2006 18:54:20
The 4 cyl engine is listed as 24 hp. I am searching now for the additional info, The engine is NOT the same as the 1010 tractor. It looks to be 2 dubuque engines made into one. It will bolt to a dubuque bell housing and the front of the engine is very similar to a dubuque engine. they even have a double water outlet from the block to the radiator that looks as though 2 dubuques were put together. The fan assembly and the oil filter is the same as the Dubuque tractors. It has the magneto system on it for the ignition. A starter from the late 420 and 430s will fit in the hole where the starter would be on a tractor.They are an interesting piece as they were some of deeres early 4 cyls. I purchased one to restore as I had never seen one. I can post pics if interested.
Mike M
08-21-2006 05:34:13
 Re: 4 cylinder power unit questions in reply to WV2cyl, 08-20-2006 18:54:20
I have also seen those on #25 combines.
I thought maybe some of the pullers would bolt one in an MT and see what they could do ?
WV2cyl
08-21-2006 05:46:22
 Re: 4 cylinder power unit questions in reply to Mike M, 08-21-2006 05:34:13
They were used on the 25 and 30 combines, I am not sure of other applications. I have a 40 and a 430 parts tractor that I am checking to see if I can fit the engine.
Glen in TX
08-21-2006 10:19:35
 Re: 4 cylinder power unit questions in reply to WV2cyl, 08-21-2006 05:46:22
JD Publications catalog DB1112 (Feb.94) list the following for the HA-92 power unit under power units listing.
OMT1453 Operators Manual
PC312 Parts Catalog
PC312 also covers the EA-82, TA-92, TB-92-G, & TB-92-N power units.
Under another listing: COMBINE ENGINE (Power Unit) it also lists the SM2026 Service Manual (Mar63) as for the 92 (for 30,45,55,55H,95 & 95H combines)
You might see if a local older JD dealer has copies of those and they are truely what you want before ordering. If the SM2026 is anything like the SM2080 I have for later JD combine and swather engines it's worth buying. JD Publications 800-522-7448
