1972 John Deere 4320
Dean Barker
08-20-2006 18:14:00
My 4320 Has a small amount of hydraulic oil leaking into the rear part of the clutch housing. Both shaft seals, gaskets, and pto actuation "O" rings have been replaced. There seems to be nothing else that can leak back there. Anyone have thoughts on this? Thanks.
ET
08-21-2006 11:39:15
 Re: 1972 John Deere 4320 in reply to Dean Barker, 08-20-2006 18:14:00
The shaft or seal bore may have been scratched or gouged when the old seals were removed.
msb
08-20-2006 20:01:34
A seal could have been damaged on reassembly of the tractor.
You say both shaft seals? Meaning the seal on the end of the PTO shaft inside the clutch pack and the PTO shaft seal inside the middle section?
Dean Barker
08-20-2006 20:22:54
 Re: 1972 John Deere 4320 in reply to msb, 08-20-2006 20:01:34
Yes, both seals were replaced, the one between the pto shaft and the housing and the seal between the pto shaft and the transmission shaft.
I ran it about 30 hours with no apparent loss according to the dipstick, but clean oil is being thrown out the inspection cover on the right side and the joint on the left side. The dealer thought it might be a porous casting. All this time the pto is disengaged. The oil is coming from the back of the casting as the bottom hole between the front and rear of the clutch housing was plugged and the front half stayed dry. When the plug was removed, oil came from the back half.
buickanddeere
08-23-2006 18:20:06
 Re: 1972 John Deere 4320 in reply to Dean Barker, 08-20-2006 20:22:54
Is there drain holes in the casting grooves to allow seapage to run back into the trans? Sometimes these are ignored during overhauls and get plugged up worse instead of being rodded out.
