JD 50 power steering pump
Jack in Ohio
08-20-2006 05:31:26
The manual says to put a tin layer of shellac on the pump housing body and end covers when assembling them. What have you folks used? There was nothing on it when I took it apart, but it was also leaking.
Thanks
Jack
Bob
08-20-2006 08:42:16
 Re: JD 50 power steering pump in reply to Jack in Ohio, 08-20-2006 05:31:26
Third Party Image
A modern prodict that's even better is Anaerobic Flange sealant:
Third Party Image
Dan in Ohio
08-20-2006 08:11:58
Jack, I have used a shellac like gasket material (forgot its name) that I bought at NAPA on a hydraulic pump. Just clean and smooth the mating surfaces and apply a thin coat, works well.
