CFWelles
08-20-2006 05:03:14
I have an electric start WF that I bought about two years ago and finally put to some legitimate work on my old farm with an MX7 cutter. Tractor had a PTO area rebuild and a governor rebuild. This is my first two cylinder and was warned about buying the diesel as a first, but have found the unit to be beautifully and logically engineered and built and an absolute joy to work on if you admire simple effective engineering. I just wanted to comment here as I have received very appreciated support from the likes of Glen in Texas, 720D, FIT, Buick, and a few others as I worked on this in my spare time. First, as is widely known this tractor is tremendous on fuel consumption. Mowed five hours in high grass in third gear near max power the other day and burned just shy of 7 gallons. Don't know if the energy balance adds up here, but I know this is absolutely great fuel efficiency. Am really impressed. Governor: after reworking due to a thrown weight, have found the governor has settled down after about fifteen hours of operation following rebuild. Wanted to hunt about 50 rpms at low speed after first rebuilt, but now is steady wherever it is set. Power: The MX7 appears to be the right choice for this tractor as it will cut about anything including anything up a good grade in 3rd gear. Engine: I feel this tractor likes to run about a hundred rpms under design speed. Pulses just sound and feel a little smoother around a 1000 rpms. Transmission: This is my remaining problem area from purchase and would appreciate a comment from someone who has been into one of these transmissions. Transmission will lock up into first and reverse gear simultaneously sometimes if you shift between the two. Also slides quickly out of fourth when going down hill. Gears sound good when traveling. Doesn't this mean that my entire transmission problem is in the top in the selector area as in worn out? When the transmissin locks up, you can unlock it buy going to the other side of the quadrant and then shifting back over. This will get it out of reverse gear. Also my transmission has first, reverse, second, and fourth on left side and third, fifth, and sixth on right. Would appreciate any comments on the shifting problems I am having. Am planning on going in to fix this problem this winter. One final comment: Have owned a wide range of machinery during my years and do some design and fabrication from time to time. This tractor, 1959 730D ES, is in my opinion the finest piece of equipment I have ever had the privilege to own, maintain, and operate from the standpoint of pure design effectiveness, technology in its place in history, function, and pure joy of operating. Spending four hours on this piece carefully putting it through its paces gives me more peace of mind, pleasure, and positive feedback than operating anything I have ever run. That includes airplanes (Have private pilot license,) sports cars, and all other machinery. I STRONGLY RECOMMEND ONE OF THESE TRACTORS TO ANYONE WHO IS THINKING ABOUT BUYING ONE. NO WONDER THAT THIS TRACTOR IS ONE OF THE MOST POPULAR VINTAGE JOHN DEERE'S FOR TODAY'S COLLECTORS.
