G head gasket installation
RLS in PA
08-19-2006 18:45:12
I read in an IT service manual to install the head gasket with the flat surface toward the block. How important is this with a new gasket from Deere?
P Browning
08-20-2006 04:40:04
 Re: G head gasket installation in reply to RLS in PA, 08-19-2006 18:45:12
Whether the new gasket comes form Deere, FelPro, Lubbock or somewhere else, you are advised to install with the smooth side (usually the metal side because you have crimps on the unsmooth side) facing the cylinder block. Look at your gasket, and in particular, look at the rim around the cylinder bore area. You will see where the metal layer is crimped. This crimp is the firing ring and is to face the engine head. With some gasket brands, I am told that you may find the water passages with their crimp running the other way -- this is not significant in terms of orientation of the gasket. (PatB)
