John Deere D mag
bigtim
08-19-2006 18:29:56
HELP John Deere friends I just bought a base type witco type c mag for a 1931 john deere D tractor but when I bolt the mag down it doesn't reach the drive coupler on the governer do I need a certain kind of drive coupler?
Glen in TX
08-19-2006 22:36:30
 Re: John Deere D mag in reply to bigtim, 08-19-2006 18:29:56
The Wico C & XH 1263 base mount mags for D & GP came originally with the 4702 long lug drive cup with 1/4" wide tangs. You used the 1/2" wide M47X float coupler with that drive cup. Later the 4702 drive cup was discontinued so the short lug 1/4" tang 1657 drive cup was used in it's place and you have to use the longer M23X float coupler with it. Sounds like you just need the longer phenolic float coupler M23X that is 55/64" wide x 1 3/4" O.D. You should also have 2 sets of bolt holes in mag base. If you can't find the right float coupler let me know as I should have some. You can also make your own from some UHMW plastic or fibred phenolic.
bigtim
08-20-2006 20:08:42
 Re: John Deere D mag in reply to Glen in TX, 08-19-2006 22:36:30
Thanks for the help Glen in TX my mag is a wico c 1263 with the long lug drive so I need a m47x float coupler I should be able to find one in Illinois if not I"ll check back with you later bigtim
Duane Larson
08-19-2006 19:55:05
bigtim,
First I would go to the following site and look at the couplings - you may have the short coupling. If this is not the case, you may have the wrong magneto mounting bracket - if so, post back with your s/n and we'll go from there.
