1020 Owners - Hydraulic Capacity (Misprint??)
TG
08-19-2006 14:06:22
I drained the hydraulic fluid, cleaned the filter screen, changed the filter and added the 10 gallons as listed in the operator & service manuals.
It now shows to be about double full on the dip stick.
Whats the deal?
jdemaris
08-19-2006 19:05:51
 Re: 1020 Owners - Hydraulic Capacity (Misprint??) in reply to TG, 08-19-2006 14:06:22
I've got two of them (actually, one is a yellow 300 and the other a green 1020) and they both hold around 10 gallons. Maybe you didn't drain it all the way? It you only pulled one drain-plug, it takes time for the oil to work it's way out of the transmission case and the differential case and final-drives. Also, even when drained, a gallon or so will be stuck in the hydraulic pump, transmission pump, lines, reservoir, brakes, steering, rockshaft, etc. Even more if you have the independent PTO, reverser, or hi-low.
