B clutch drive removal
Gene-WI
08-19-2006 03:07:20
I have a JD B that I have to replace the camshaft in, but I am having trouble pulling the clutch drive disc off the shaft, in the book they showed using a two jaw puller behind the gear, but I tried that and also pulled using the two bolt holes along side the gear but can't get it to budge. Any ideas on how to get it off, or what I'm doing wrong? Thanks Gene
Mike M
08-19-2006 10:49:34
 Re: B clutch drive removal in reply to Gene-WI, 08-19-2006 03:07:20
After you get the puller tightened up give the end a real HARD whack or two and it should pop off.
Kurt_JDB
08-19-2006 09:48:04
Gene, I"m assuming your talking about getting the clutch driver loose from the crankshaft. They can get stuck on there pretty good because of the tapered spline, but the good news is that once they pop loose, it will come right off. The way I did it was to remove the bolt and large washer from the crank, and then put the bolt back in so your puller has something to bear on. I used the type of puller that has two bolts that you screw into the part you want to pull (the clutch driver), with a center screw that pushes against the end of the crank, It is important to use a quality tool here. Put the tractor in high gear and set the brakes/block the wheels and pull.
By the way, I remove the sparkplugs wires and sparkplugs before I fool with turning the engine over with a tool. You sure could accidently start the engine otherwise. Be safe.
Kurt
