710 or 1010 which is it?
schramm
08-18-2006 23:13:37
I"m looking at a tractor to buy that has 2 tags.The one on the loader frame says model 710,serial 149 and the tag on the engine block says model 1010,serial 16433.
I can"t tell what tag is for the tractor,I looked up model 1010 tractor"s and they are painted green and appear to be farm tractors,but this tractor is painted yellow and has a factory loader and gannon setup like a skiploader.
It has a hyraulic pump mounted on the crankshaft and the bucket arms are the hydraulic oil reservoir.
The steering wheels attaches to a shaft that goes through the fuel tank and then through the radiator to a gear box in front of the rad and the down to the axle.
The head also is strange in that it doesnt have a valve cover but instead a cast iron piece that the intake manifold bolts to.this cast piece also has water flowing into it.
Is this a rare model or are they pretty common?I"ve never seen another like it.
Thanks for your help with this...schramm...
jdemaris
08-19-2006 06:58:22
 Re: 710 or 1010 which is it? in reply to schramm, 08-18-2006 23:13:37
1010s, wheel and crawler, came in green-ag versions and yellow industrial. Industrial 1010s commonly came with #30 forklifts, #76 dozers, #10 winches, #35 rippers, #602 dozers, #810 and #710 loaders. As far as raritys go - I think the green-ag crawlers are pretty scarce - but I've got one and we sold a few years back. About your lack of a valve cover?? I don't understand that. All 1010s have overhead-valve engines with a valve cover. With some, it's hidden by the gas-tank mounted over it. 1010 engine also has a separate water-manifold close to the intake/exhaust manifold.
buickanddeere
08-19-2006 05:57:51
310, 510 & 710. It's Lance 10 speed tractor with a 20 series Deere engine. The 1010 is a five speed. The back 1/2 of te tractor looks like a 430 two cylinder. The 2010 uses a 8 speed syncro range if you can get the rest of the tractor to run.
