JD 1020
big daddy
08-18-2006 19:17:05
I have JD 1020 that has recently started leaking water from the overflow tube of the radiator. I don't know why. The anti-freeze looks real foamy when it comes out of the overflow tube. I lose about 2 quarts of water/anti-freeze in an hour. I am planning on changing the thermostat and radiator cap. Does anyone know if this will help solve my problem? The temperature gauge seems to be working properly. Any help would be greatly appreciated. Thanks.
buickanddeere
08-18-2006 19:55:31
 Re: JD 1020 in reply to big daddy, 08-18-2006 19:17:05
How old is the anti-freeze and what did it test the last time you checked for nitrates etc? Odds are it's the original antifreeze and the corrosion inhibitor was used up years ago.Now there are holes pitted through the engine's wet sleeves. Sometimes even the block erodes away.
