HEAD TORQUE ON 1949 JD A WHAT IS IT??
THE JUNKMAN
08-18-2006 08:07:17
The nine head bolts what are their torque? AND is that the same torque for the two bolts that hold down the rockers? Thanks
Jim
buickanddeere
08-18-2006 08:33:51
 Re: HEAD TORQUE ON 1949 JD A WHAT IS IT?? in reply to THE JUNKMAN, 08-18-2006 08:07:17
At least used all new nuts and hardened washers. Late A's and 60's will leak if the fasteners are stretched or brittle. The head and block have to be flat or odds of a leak are good.
P Browning
08-18-2006 08:31:18
JUNKMAN-- Frank has it on the money for the head nuts onto the studs -- well lubed (no resistance threads) & use of lead washers as called out.
No specification is given for the rocker arms. Good N Tight may be just fine, but if you are prone to overtighten things, do not exceed the Grade 5 torque value for the fastener's diameter; Limit to 54 ft-lbs for 7/16", and/or 78 ft-lbs for 1/2" diameter -- these from standard torque charts available everywhere. (PatB)
F-I-T
08-18-2006 08:16:22
Someone with a book or a service bulletin will get you the correct value, but for now I recall it to be 125 ft-lbs, but then there is a note that if you have the darker, heat-treated studs I think it can go as high as 150#, but I am guessing so wait for validation.
On the rocker bolts, no they certainly do not get torqued as tight as the head nuts/stud because they don't go through to the block, they just screw into the cast iron head. If you lay on those really tight, you'll break a chunk out. I always just leaned on a wrench until it felt it had German torque...."Gudentight".
Frank
