301A PTO
TomIN
08-18-2006 03:27:21
I recently bought a 301A industrial tractor. I'm a big fellow, and just reaching the PTO engagement lever with the seat all the way back and the clutch depressed is difficult, at best. The lever seems to want to "stick" in either the engaged or disengaged position, but eventually works with enough fiddling around. Is there something to adjust to make the engagement.disengagement easier? Is there some reasonable way to extend the lever so that it is easier to reach?
Roy Suomi
08-18-2006 19:50:03
 Re: 301A PTO in reply to TomIN, 08-18-2006 03:27:21
Either the clutch disk is dragging [ or sticking ]. or the PTO coupler is rough on the splines..And yes , you can extend the lever .It's just mild steel , the lever can be welded and added to...
