As far as I know, the steering shaft is not available, but the female portion, the actuator sleeve is, but it is very expensive. To rework those splines would mean broaching and that is very expensive. The two parts are meant to have a bit of axial (in/out) movement to a slight extent, and this is what helped to promote wear. If you have good splines above the joint, some folks cut 3/8" or so off the end of the shaft, re-drill the roll pin hole in the shaft, and fresh shaft splines will take up much of the play. On my 70D, I cut a hacksaw slot in from the end of the shaft, then pushed a slim wedge of steel in from the end to spread the old splines. I mike it and set to be just the same diameter as the fresh, un-worn splines. I test fit it and when I was pleased with the just a nice drag fit, I put a dot of weld right on the end of the shaft to seal the split and secure the wedge. It really tightened it up. Now what would be great would be if some one would broach an internal and an external sleeve that you could install in the actuator sleeve and on a turned down end of the shaft at time of a major overhaul of the steering parts. That would make them like new.
