D oil leak at crankshaft
jas
08-17-2006 18:41:18
I've got a 29 D that leaks oil on the flywheel side. I picked up the cork seal at the dealer and took the tractor apart. Much to my surprise there was no seal in there. So my question is Where does this cork seal go? I looked at the parts break down but it doesn't make sense to me. I can't imagine that it goes between the oil slinger and the housing so it must go around the slinger? Does it fit the middle widest groove of the oil slinger? If so, How does a guy stretch it enough to get it over? I looked to make sure all of the oil holes are open and also to make sure that the oil can flow back to the main case and all looks good. Also is it pushing oil because there is no breather on this tractor? Where does the blowby go? And finally, I pulled the governor and noticed that the idler ger between the crank and gov. gear is loose. So I pulled that too. The pin looks good and doesn't appear wore. same as the bushing until you mic it. it has about .022 clearance? Is this bushing available or does a guy make one? Thanks
jas
08-18-2006 16:37:14
 Re: D oil leak at crankshaft in reply to jas, 08-17-2006 18:41:18
I think I have it figured out. My slinger/spacer does not have a grove for the cork seal! Also this 29 has an earlier crankshaft in it. It is keyed instead of splined. So either I have a slinger/spacer off of something else or the early D's didn't use the cork seal. Despite what my JD dealer tells me that styled and unstyled D's used the same seal. Anybody got any ideas now?
Glen in TX
08-18-2006 16:51:00
 Re: D oil leak at crankshaft in reply to jas, 08-18-2006 16:37:14
third party image
jas, You are right! We were all thinking about the styled D AD2743R slinger that does use the cork seal ring. Parts book shows AD2742R for the early D and I don't believe those had a cork seal. Been too long since I've been in one of those. Seems like put a seal of some kind in that early slinger or modified a later one to fit? I can't remember now what we did on the 28? If that cork you have fits the crank okay you might machine out the back side of your slinger and put it in there. The slinger has to be in there as a spacer also so don't want to cut down the width any. The pic shows the AD2743R styled slinger spacer and you will notice the dowel pin groove is worn. That can be built up on your old one. It's when the pin has broke off and slinger has spun on the crank and worn a groove in crank or worn inner bore of spacer you need to be concerned about.
jas
08-18-2006 21:07:39
 Re: D oil leak at crankshaft in reply to Glen in TX, 08-18-2006 16:51:00
Thanks glen, If you look close at the picture you sent it looks like just what I have. I'm going to the dealer tomorrow to see if there is any seal at all. Somebody here locally said to put an o-ring in the small groove on the inside. Might try that if I can't caom up with anything else. Tried looking at a later tractor and the spline ends of the crank are smaller so I have to use this larger slinger. The cork seal that I got has to be stretched to fit but I can get it on. I may just chuck it in the lathe and widen the slot to accept this cork seal. Anyhow at least we got it figured out!!!! Thanks to all.
Glen in TX
08-18-2006 22:15:37
 Re: D oil leak at crankshaft in reply to jas, 08-18-2006 21:07:39
Measure your seal area on that keyed crank and try this but Earl tells me you can machine it out and use a 27225 CR (Chicago Rawhide) lip seal. If that doesn't work just measure and find a lip seal that will fit crank area and machine the spacer for it to fit inside. It does sound better to me than a o-ring or cork seal and I'll probably try it on one later.
Glen in TX
08-18-2006 14:47:11
Jas, I've also heard from others saying they used a regular lip type seal on there in addition to the slinger. Never tried that myself but something to think about if it still leaks. The slingers do wear also and I've replaced several of them on Ds. Don't think you can get the slingers from JD anymore so might have to rebuild your old one or watch ads for a NOS one or see if Greg Stephens has one? theoldtractorcompany.com
Model D
08-18-2006 12:14:27
The seal goes inside the groove of the slinger.The oil seal and slinger will become 1 part and slide on the crank as an assembly.
jas
08-18-2006 07:48:26
Glen, Are you saying that it goes on first then the slinger and then the housing? How would it last? Doesn't the flywheel set the end play? If so, It would get pinched and burn out? Or are you saying that it fits over the slinger? Thanks
Glen in TX
08-18-2006 14:42:44
 Re: D oil leak at crankshaft in reply to jas, 08-18-2006 07:48:26
As Model D said above it goes in the slinger groove. You don't want to soak it in water but I've had to soak them in oil before to get them on or put oil on after they go in groove. Have also had poor fitting ones that were too shrunk I returned to JD also. They usually are impregnated with graphite and if not and just plain cork mix up a graphite oil mixture to install it with.
Glen in TX
08-17-2006 22:36:27
That cork ring seal goes in back side of slinger against crank. You might have to soak it in oil some to get it to swell and go on. There wasn't a ventilator on early Ds. Later Ds had a crankcase breather and oil fill inlet and a ventilator tube from governor housing to air cleaner outlet to carb. Some drilled a small hole at angle on pipe cap on early Ds or put breather on instead of cap but many didn't put a outlet on it.
bob-wyo
08-17-2006 19:24:49
jas if you hurry there is one on ebay
Item number: 250017382448
