430w hydraulics
Donald Scott
08-16-2006 16:37:17
I had a leak in a hydraulic line and took it off to silver solder it and lost some fluid. After I put it back on it didn't lift real good but it did lift. The next time I started it there was a knocking in it and then the rpm's went up to 2400 before I shut it off. Now the engine is locked up. Could the pump be dry and ruined that is causing the lockup?
machinery-man
08-17-2006 04:53:06
 Re: 430w hydraulics in reply to Donald Scott, 08-16-2006 16:37:17
piece of solder in pump locked it up? Never had any luck with solder on lines, one might braze. Sounds like more problems than leak. I"d take pump off and inspect then see if engine turns over...
neilho
08-19-2006 04:34:36
 Re: 430w hydraulics in reply to machinery-man, 08-17-2006 04:53:06
The engine has more than enough horsepower to split the pump wide open if it gets something like solder in it. In any case :-), a pump problem doesn't explain the jump in RPM. A governor failure does- there's not a lot of room around the weights, so it'd be easy for loose parts to jam up the works. IIRC, the front end has to come off to get at it, but it's not too complicated- just a fair amount of wrenching.
Donald Scott
08-21-2006 13:17:42
 Re: 430w hydraulics in reply to neilho, 08-19-2006 04:34:36
Thanks for the replies. Another question I have though is, where do you put hydraulic fluid in the system and how do you know how much to put in?
