The mechanical pump on my 4020 wasn't pumping (except maybe to the crankcase). It was worn out. The Deere price for a replacement was over $60 and it looked like it would fall apart at the connections and does not come with a filter screen or visible bowl. It looked like it was (and it probably was) made in backwoods Cambodia. The electric pump (ignoring the metal work I did) was under $20 and I like to let the electric pump fill the carburetor before cranking which saves on battery and gets me a much quicker start. The MS carburetor gets 4 or 5 times as many pages in the 4020 shop manual as the Zenith. But there is a 70s vintage JD service bulletin that says scrap the MS and put on a Zenith, so its sure that they often couldn't tune it either. I suspect the most common problem is a break in the vacuum operated accelerator pump diaphragm but my 4020 came with a Zenith and I'm not going to change to MS for the education of the experiment. A worn distributor top bearing could easily lead to poor running especially if the rattle off the shaft is a significant fraction of the point gap speecification. But that shouldn't show up after 20 minutes, that should be poor all the time. With the time frame of this particular complaint, I'm more inclined to believe its fuel supply rather than coil or ignition failure. The solid state ignition probably isn't going to come back to life after failure, nor is the condenser in a normal ignition (which has many fewer parts to fail compared to a solid state ignition), though coils can develop a shorted turn when warm and work again when cool. With this time delay, a lack of tank vent can be a problem. There's a service bulletin about that, recommending that the gas cap not quite bottom against the hood grommet because the passageways are on the bottom of the cap and being against the grommet can block them. So when it sputters, pull the choke on to see if that help. If that does, take off the gas cap to see if that helps. Then adjust the gas tank neck extension to raise the cap above the grommet. But do the simple things first. Gerald J.
