336 baler shearing flywheel pins often
Ted K
08-16-2006 13:58:02
My 336 baler with #30 thrower works perfectly for about 200-300 bales, then for no apparent reason will shear the flywheel pin. The plunger stop IS NOT causing it and it doesn't happen when a bale is being thrown. It seems like when I'm baling with it, either tractor I use on it, 730D or 4020D, is surging every time the plunger goes back, much more so in grassy hay or straw. Knives are sharp, bales look great. I'm thinking maybe the knives could be closer together so it shears the material easier. How close are they supposed to be? Could it be wear on the rollers and slides causing the knives to move apart in operation but look OK sitting still? Other 336 owners I know don't have this problem so it has to be something I am overlooking. Any suggestions will be appreciated. Thanks.
Ted
johns48b
08-18-2006 12:34:49
 Re: 336 baler shearing flywheel pins often in reply to Ted K, 08-16-2006 13:58:02
sounds like you have got bearings or guides that are worn out on the plunger. ih balers have an adjustment on them to tilt the plunger in or out a little bit to adjust knife clearence. if the knives are hitting they should show evidence that they are. it also sounds like you may be bailing your bales to tight. on some balers i have had to remove some of the plates on the sides to keep the bales from being to tight. i always had better luck keeping the shear bolt tight. if i ran
Ted K
08-17-2006 09:30:44
Thanks for all the input. I do notice quite a bit of wobble twixt the flywheel and shaft so will be replacing the bushing there. As for the slip clutch, when the pin does shear, the baler will continue to bale almost like when the pin is intact, or in other words, the clutch does not seem to slip at all. I'll remove the clutch soon and make sure it can slip, must be frozen tight for some reason. Otherwise, it's sure a dependable baler, very rare for it to miss tying a bale, even when changing twine balls. Thanks again everyone.
Ted
Roger in Iowa
08-17-2006 10:49:25
 Re: 336 baler shearing flywheel pins often in reply to Ted K, 08-17-2006 09:30:44
You do not have to remove the clutch. Just loosen all the adjusting nuts. You may have to help separate the parts or engage the pto with a block of wood in the knife area to stop the plungerhead and cause the clutch to slip. Spec for slip clutch should be in the OM.
Yes, you can continue to bale with the pin sheared but it is hard on the clutch, as it should slip, and pto powerline. Do not do it.
Roger in Iowa
charlesmm
08-16-2006 23:27:59
surely if the slip clutch slipped a little each stroke then this would allow the plunger to decelerate faster, thereby using more of the flywheel's kinetec energy, so putting more strain on the shear bolt Just a thought ??
Roger in Iowa
08-17-2006 07:13:13
 Re: 336 baler shearing flywheel pins often in reply to charlesmm, 08-16-2006 23:27:59
The slip clutch slipping takes away some of the reversal on the shear bolt. One moment the shear bolt is driving the plungerhead and the next the tractor is putting lost energy back into the flywheel,in the opposite direction. If the slip clutch does not slip, it is harder on the shearbolt and the pto driveline.
Roger in Iowa
phil2
08-16-2006 17:30:32
Something to watch - if you overtighten the shear bolt it will be loaded in both shear and tension - it is actually stronger w/o tension, ie, loose & double-nutted.
Roger in Iowa
08-16-2006 14:13:08
Obtain a manual to get specs for the knife clearance.
Several other items to check:
1. Worn shear bolt bushing in flywheel. Replace the bushing
2. Worn shear surface in the drive arm to the flywheel. Replace the arm
3. Excessive clearance between the two above.
Above cause bolt to fatigue and fail.
4. Worn bushing in the flywheel to the shaft causing flywheel to wobble. Fatigues bolt.
5. Overtightened main slip clutch. It should run warm and should slip at each stroke at capacity.
Good luck,
Roger in Iowa
WyoDave
08-16-2006 14:05:23
How much wear is there where the shearbolt goes through the flywheel and the arm the fly wheel bolts to? If those get worn and there is slack there it will shear bolts. The flywheel has a bushing in it that can be replaced. Secondly is your slip clutch slipping? They have to slip just a bit every time the plunger runs, and if its frozen up tight it will shear pins as well. Just a couple things to look at.
David
