46 JD Li fan assembly
Johnny Barbour
08-16-2006 11:25:38
Im trying to find what grade lube goes inside this fan assembly
Mike M
08-16-2006 11:55:02
 Re: 46 JD Li fan assembly in reply to Johnny Barbour, 08-16-2006 11:25:38
As those have no replaceable seal it may be more of a question of what weight you will need so it stays in there ? You may end up trying corn head grease ?
I was able to find a thin oil seal that fit the shaft and then attach it to the back of the fan hub with epoxy to make a new seal for my model LA and M tractors. You have to watch out for clearance. I think the book just called for motor oil same as in engine.
