Broken Eye bolt on front of BR
Marty Z
08-15-2006 22:28:07
I am about to try to get the broken eye bolt out and wonder if anyone has had success at this. There is nothing left above surface except the bad weld repair job that I will grind off. It is quite a hefty bolt thread and has to be about 3 inches of depth. Not sure if I should heat this much casting on the front end. Will I cause more damage than it is worth?
I can't be the first one with a broken eye bolt. What works?
Thanks
Marty Z
JRB
08-16-2006 15:03:06
 Re: Broken Eye bolt on front of BR in reply to Marty Z, 08-15-2006 22:28:07
I've done three of them and had no problem with this method. I drilled the original eyebolt and backed out what was left with an easyout. Use the largest easyout you can find, that way there's very little eye-bolt material left. If you can't get it this way, drill as much out as you can and use punches, chisels, picks, whatever to remove what's left in the threads. It'll work.
