Danes Dad, Your friend is correct - the AC 88L Com (now C88L) was used for light/medium service in the late styled A and B models with gasoline engines. Deere started out with 6Com Champion plugs (and Edison Splitdorf plugs - the number is in the house) in the gas burners when they were introduced in 1947, and within a year went to the hotter 8Com, and within another year needed a hotter plug yet, which Champion did not have, so they went to an AC 88L Com plug. Within 6 months Champion came out with the 10Com64 plug as a competitor to the AC 88L Com as they didn't want to loose the Deere OEM business - and Edison was out of the spark plug business in December 1950 so Deere needed another backup supplier and AC was it.The C88L plugs are still good plugs, and are non-resistor plugs, as opposed to the Autolite 388 (and 386) which are resistor plugs. If you like Autolite, try the 3116 non-resistor plugs. You might also hunt around for AC TC88L plugs - they are labeled Tractor on the insulator - Don McKinsey, P.O. Box 94, Wilkinson,IN 46186 probably has some as he is the largest supplier of NOS plugs. Way more than you wanted to know, I'm sure...
