Head installtion on A.
jdjack
08-14-2006 17:09:51
Will be installing the head back on the A.
Had one stud turn out of the block. It goes into a water jacket. Would medium strengh lock tight
work to hold it in and seal it from the water?
Also should anything be installed on headgasket, (alum. paint). I once had a headgasket leak water, just sitting from a few days before it was started.
So should head be installed and torqued, started and warmed up and retorqued?
Just curious was to what other people have done.
Also could somebody post the torque spec for the head.
THANK YOU
JDJACK
Glen in TX
08-15-2006 04:59:05
 Re: Head installtion on A. in reply to jdjack, 08-14-2006 17:09:51
A coppercoat sealer or the Permatex aviation sealer are ones that work well on the metal head gaskets. It takes several wet heavy coats with the aluminum paint and I like it better for the composition head gaskets. If threads are stretched on stud you may need another one or block thread repairs. The teflon sealers seem to be a good choice many use on the studs.
DSK
08-14-2006 20:48:46
The correct torque for the head nuts is 150 ft. lbs. All I have ever used on the block ends of the studs is several wraps of teflon thread seal tape. As far as gasket sealants go, I never use any if both surfaces have been surfaced at a machine shop, but otherwise I give them a coat of Permatex Coppercoat.(aerosol) Although not always necessary, it's a good practice to remove the rocker assembly and re-torque the head after several heat-cool cycles.
