1948 JD A Idle
almrm
08-14-2006 15:12:51
I posted for help with my 48 A back in July for surging, hunting, galloping, pick a name, when it idles. I was advised by PBrowning and others that my idle passages were likely blocked. I ordered the drills from Robert's Carb and cleared the perscribed passages. The tractor now runs fantastic at all engine speeds. It was starting on the third revolution and now it starts on either the first or second compression stroke hot or cold. If you are having similar simptoms, I highly recommend this process.
Thanks for the help,
Mark
Glen in TX
08-15-2006 05:19:18
 Re: 1948 JD A Idle in reply to almrm, 08-14-2006 15:12:51
I'm sure everyone that advised appreciates knowing what you found to cure the problem.
