2010 coil question
Dave / Believer
08-14-2006 10:31:35
I need to replace the coil on my 2010. The ones I find at auto parts stores say you need a resistor or resistor wire to run them. Can anyone help me with this? Mine is wired to the points and to the ignition switch, no resistor in sight.
Thanks -- Dave / Believer45
Dave / Believer45
08-15-2006 00:34:47
 Re: 2010 coil question in reply to Dave / Believer45, 08-14-2006 10:31:35
Thanks for the replies. The tractor as a 12 volt system, I am using a Delco alternator. There is no resistor or ballast in the wiring, the wire to the coil from the ignition switch has battery voltage (12.5) at the coil end. I have located a 12 volt coil with internal resistor and will pick it up in the morning.
Thanks again for the help.
Dave
John T
08-15-2006 06:13:37
 Re: 2010 coil question in reply to Dave / Believer45, 08-15-2006 00:34:47
Dave, Youre welcome and I hope your correct but Im still not convinced you need a 12 volt coil. If the wire from the ignition switch is a resistive wire link or a thermistor wire link (can look kinda like regular wire) that will drop 6 volts when warmed up and if you then use a 12 volt (internally ballasted) coil, the spark will be weak. When you say theres 12 volts at the coil that measurement must be taken with all wired up and a good coil and a good set of points being closed (they normally are, however). Even with a discrete ballast or resitive or thermistor wire there would still be battery voltage on the wire or ballast end until a conductive load (like the coils primary) is attached.
Im sorry I just dont know what system that tractor uses and maybe its a true 12 volt coil without any ballast or resistor or thermistor wire link but it might also be a 6 volt coil??? With the wires and coil connected and the ignition on and if good points are closed and let her draw current to warm up a bit and if it still reads 12 versus 6 volts, THEN I GUESS IT USES A 12 VOLT COIL AS YOU INDICATE YOURE GONNA PURCHASE???
Wheres some new generation fellers when we need them that can shed some light here???
John T
Bob
08-14-2006 23:27:27
As usual, JohnT has a sensible answer.
Maark and old, you are "shooting from the hip".
A quick check of JDPARTS shows 3 coils used, which sub to 2 coils.
One choice is a Delco, which is a 6-Volt unit, the other is for use with a Prestolite setup, and voltage is NOT specified.
Some or all of these tractors use a ballast resistor and a 6-Volt coil, and there may have been some changes as to whether the ballast resistor is on the ignition switch, or a discreet unit.
Is the distributor a Delco or a Prestolite? Is there a manufacturer's name, and perhaps a part number on the old coil?
Duane Larson
08-15-2006 07:40:35
 Re: 2010 coil question in reply to Bob, 08-14-2006 23:27:27
I agree with Bob that some further study is needed. At least measure the primary resistance of the existing coil - if it measure around 1 ohm or so it is a 6V coil, 3 ohms or so it is a 12V coil.
Has the tractor's original wiring been changed? The 2000 series service manual is not much help as it doesn't discuss bypass starting but the wiring diagram appears to show it. I didn't study it carefully (late last night) but I didn't notice a resistor in the ignition circuit.
A parts book for a 2010 is needed but I don't have one. JDParts provides at least some info about the coil - that is why I am wondering if it has been rewired. Tisco also lists a 6V coil for a 2010.
John T
08-15-2006 06:15:55
Bob, based on your good info regarding what coils are available, Im still suspicious that tractor may have used either a resistive wire link or a thermistor wire link after the switch and before the coil, heck if I know lol maybe its a full 12 volt system and coil????? ????
John T
Bob
08-15-2006 14:08:55
 Re: 2010 coil question in reply to John T, 08-15-2006 06:15:55
JohnT,
On jdparts, the Delco coil IS specifically listed as 6-Volt, but no "specs" are given for the Prestolite.
John T
08-14-2006 14:21:57
Dave, anything after the 2 bangers is out of my area of knowledge, that being said, however, I believe some of the new generation used a resistive wire link or a thermistor (increases resistance after warm up) wire after the ignition switch and ahead of the coil as opposed to the older discrete ballast resistor. If thats the case, you need a 6 volt coil and NOT a full true 12 volt (internally ballasted) coil.
To solve this riddle you need to know if the 2010 used a resistor wire or a thermistor wire or a discrete external ballast (I dont think so) in series after the ignition and before the coil. If they did it likely takes a coil labeled FOR USE WITH AN EXTERNAL BALLAST which is a 6 volt coil BUT IF THEY DID NOT USE ANY BALLAST (or wire or thermistor) then you need a full true 12 volt coil. They may be labeled 12 volts or 12 volts NO external ballast required.
Find that out and then buy the appropriate 6 volt (if it has ballast or resistor wire or thermistor) coil or else a true 12 volts coil (if it uses uses NO ballast of any kind)
John T
Gerald J.
08-15-2006 11:59:29
 Re: 2010 coil question in reply to John T, 08-14-2006 14:21:57
My '68 4020 uses a 6 volt coil and the ceramic resistor is mounted next to the coil. This may have been a mod because the run wire was hooked to another wire at the ignition switch with a scotchtap. There is a special contact on the starter solenoid that supplies 12 volts to the coil when cranking. When that schotchtap went open, the engine would only run while the starter was spinning. I had to hot wire it to finish raking hay. Then I took that scotchtap out of the circuit and put it in the trash.
One could emulate the 12 volts at start with a relay if the starter solenoid didn't have it. Simply hook the coil of an automotive cube relay in parallel with the starter solenoid coil and use the normally open contacts to short the ballast resistor.
I don't have data on the 2010 or 2020 at all except some service bulletins and if there's something in them on 2010 or 2020 I've ignored it completely.
Gerald J.
Maark
08-14-2006 13:40:48
Just ask for one with a built-in resister.
old
08-14-2006 12:55:43
You should be able to buy a true 12 volt coil but they just don't want to help you. The 12 volt coils are common and NAPA has them as does O'reillys either parts store should be able to help you. Now if you can't get one just get a ballast resistor from a mid 70 dodge car and wire it in line from the switch to the coil
