60 flywheel end play?
Jak
08-14-2006 07:14:56
I have the clutch wheel off and repairing the operating sleeve and installing the new crank bushing.What my question is,do I need to have the clutch put all back together and engaged before installing the flywheel and setting the end play.I think thats what I have to do but just wanted to make sure.She's all tore apart right now.Thanks.
Mike M
08-14-2006 10:23:28
 Re: 60 flywheel end play? in reply to Jak, 08-14-2006 07:14:56
Go ahead and set the end play now to .005"-.010"
Jak
08-14-2006 11:27:44
 Re: 60 flywheel end play? in reply to Mike M, 08-14-2006 10:23:28
Thanks Mike.
Bob
08-14-2006 08:13:57
I can see NO connection between setting the crankshaft endplay on the LH side of the main case, and having the clutch apart on the RH side.
