7 Inch D
gold-leaf-deere
08-14-2006 07:00:48
Has any one bored a D from 6 3/4 to 7 inch and used in them for minimal farm use, I have two D built on 12-21-36 and comtemplating having them bored to 7 inch with dual exaust.
Bob-Wyo
08-14-2006 19:36:49
 Re: 7 Inch D in reply to gold-leaf-deere, 08-14-2006 07:00:48
Hi Charles, the shop just called me today and said my 7" block is ready, (not the head tho) it will have 8.5 to 1 pistons in it. I am running 6.5 to 1 alum .125's in it now, seam so so but am disappointed in performance, just think there should have been the HP that I was told i'd have, and it may be somthing I'm not doing right. I have had this D (38) with 3/4" longer rods, 1" plates on top of the piston etc. Have a 36 now with 1.350 cap on .045 pistons and it does pretty good in 2nd gear, just to light and spins easy but won't hack high gear. Love your idea about double heading, send me your email addy and I will tell you a easy hook up for them that destroys nothing on either tractor. I have had 2 38's in tandem, takes about 5 min to hook them together. Are you doing our favorite D's, 37 or 38"S? Just keep the gold D pristine like my picture of it, if they want to hear a D run tell to listen to one of the other 160,000 of them LOL.
Bob-Wyo
gold-leaf-deere
08-14-2006 18:05:26
I tried to find the 7 inch pistons, on of the three dealers who avertise in green magazine had one set left, they must be getting the 7 inch pistons all from the same source. The block went to the shop today to get bored. My plan is to have the two D tractors running with the 7 inch pistons and dual 6 inch exhaust pipes running by 12-21-06 , The twin D's and me will all be 70 years old that day. My intention is to hook the two in tandem and plow with a six bottom 14 inch plow. Probably this noisy contraption will apease the individuals who are conserned that I won't let my GOLD LEAF D do any any barking. One more question for Glen in Texas, How much did you remove from the bottom of the block? Thanks
Glen in TX
08-14-2006 21:31:40
 Re: 7 Inch D in reply to gold-leaf-deere, 08-14-2006 18:05:26
If the fan shaft gear bearing has a big stack of gaskets under it you can get away with more off the block. We took off 1/16 to 1/8" without much trouble with fan shaft gears but when you start trying to take off 1/4 to 1/2" then you may get to modify fan shaft some to get things lined back up and have to enlarge water pipe holes for alignment some too. Shaving the back side of block some on Ds was pretty common thing in this area and wheatland areas where they were used hard and when switching to gasoline or LP for more compression. That sounds like a neat plan and to get them hitched together. Get with Bob in Wyoming as he has some nice Ds hooked together.
Earl-IL
08-14-2006 08:40:32
My friend & I built a puller "D" with 7 " bore and 1 1/2 stroke it runs really good. He has it on 15.5 -38 Tires It pulled in the 5500lb. ITPA circuit here in Illinois.Balance was a problem until they went to the 11 ft. rule on the front weight bracket. Center of rear axle to the tip of the front weight bracket.That made it and the "L" Case competitive with the "G" & F-30. He retired it and went to a component 4010- 6cyl 3 turbo alcohol burner. Quite a change? LOL We even fired a stroked crank for it and never had a horsepower gain. Crank & cam worked great. We had some vibration problems & took the crank out.We had a lot of fun doing it.Crankcase pressure was a fun fix. 2- 7in. bore pistons was like a giant air compressor.LOL.If you need help on anything send me a email. Piston are available. Earl
Glen in TX
08-14-2006 08:06:58
Had a D with the .125 overbore and shaved the back side of block off some too and it did good pulling. Actually couldn't tell much difference between it and another one with .045 high compression pistons and the block shaved more. I've been wanting to build a 7" with the .250 pistons also but everyone says the .250 overbore pistons still aren't available yet. Have you found the pistons yet? I heard you could use some CAT pistons? We never got our Ds on a dyno before selling them but always heard claims of others making 60-62 HP with a styled D with TSC high compression pistons and shaving the block down. There is a Canadian D somewhere way back in tractor photos that claimed 62HP but I never heard back from the owner of it.
