DLTX
dab
08-14-2006 02:36:47
How do you tell the difference between a DLTX 6 and a 9. Are they both brass carbs. I have what I believe is a 9 but it is stamped on it's side and could easily be a 6 I guess also. Do the bodys of the carbs look different.
dab
08-14-2006 06:43:24
 Re: DLTX in reply to dab, 08-14-2006 02:36:47
Cool, thanks guys. I got the correct one then.
Duane Larson
08-14-2006 06:00:26
dab,
If you hold the carb in your hand with the choke end next to your body, looking down from the top the DLTX6, used on the model D, has the high speed throttle stop pin in the 6:00 position while the DLTX9, used on the AR/AO, has the high speed throttle stop pin in the 3:00 position. Both are brass carbs and look the same with the above exception.
D carburetors are the only DLTX carbs with the stop pin in that position. All the rest have the stop pin at 3:00. That is one reason, in addition to the design of the butterfly, that you can't use a D carb on another Deere, or another non-D carb on a D. The governor action on a D is reversed from other models and the hole from the governor rod is on the opposite side of the throttle shaft. Hence, using a non-D carb on a D will result in a run-away engine because as the governor is trying to close the throttle plate it is actually opening it.
dab
08-14-2006 05:57:04
I have a C on mine and that I knew but I am not sure if it is the one that came on the carb. I never really thought about it till the other day I was cleaning it to put on the tractor and the stamped number is sideways and could easily be taken for a 6 or a 9 I would think. On the stem there is a LTX 8 that is stamped a lot bigger. almost 3/8 of an inch letters and numbers I would say. I would also say that all stamps are original from factory, consistant size and depth not to mention placement. I just didn't know if there is any other way to tell. Maybe the way you read it I guess. Would the buterflys be different sizes cus the one I have both choke and throttle match size and shape of other -AO/AR- carbs. I would think a -D- would be a different size there but have never worked on a -D- carb.
P Browning
08-14-2006 05:09:45
dab -- No guarantees here, but here are some data points, not to say that these factors haven't been changed. These are "from the factory" notes:
DLTX-6 carbs came on JD-D tractors, and on the atomizer plug you find the letter "D"
DLTX-9 carbs came on JD-AR and JD-AO tractors, and on the atomizer plug you find the letter "C"
(PatB)
