800 series 3 pt. on JD 60
jaredin wi
08-13-2006 21:11:20
I just finished installing an 800 series three pt. on my 60. went to test it out, and found out that the lowest it will go is 27" from the cement floor of our shop to the center of the draft link hole, this is with the adjusting links as short as they go. is this about the right height, or do i have somthing wrong with the powr-trol or the set up?
ET
08-16-2006 07:34:35
 Re: 800 series 3 pt. on JD 60 in reply to jaredin wi, 08-13-2006 21:11:20
You said your ajusting links are as short as they will go. Run them out to the midway point and then tell us how far off the ground they are.
Brent in WI
08-14-2006 20:15:14
Is it a row crop 60? With the tractor off, stand on the draft links and try to lower the rockshaft further with Powr-trol lever. You should be able to get the arms to at least 12 inches off the ground. How high will it go up? I think 36 inches is about max but not sure. I don't know if this is possible either but a remote chance would be the crank arm that connects to the rockshafts is aligned up incrorectly but I think the pin that connects the two prevents this from happening.
Mike M
08-14-2006 06:48:51
Sounds kinda high to me ? What size tires do you have on it ?
jared in wi
08-14-2006 18:50:23
 Re: 800 series 3 pt. on JD 60 in reply to Mike M, 08-14-2006 06:48:51
i have 13.6-38 on the rear.
Mike M
08-15-2006 04:53:10
 Re: 800 series 3 pt. on JD 60 in reply to jared in wi, 08-14-2006 18:50:23
Just didn't know if you had some wild size for tractor pulling ?
I'd say for sure it is too high. Those don't have as much travel as a newer style of tractor but you should still be able to get lower than that. I need to measure my model 50 but 24" would bust my knee cap and I'm sure it is only at shin busting level just sitting in the garage.
