1972 Jd 2010 with loader and 14.5' backhoe
jdb wisconsin
08-13-2006 18:14:50
I recently came across a 72 JD 2010 tractor that appears in good condition with a loader and backhoe for $7000.00. is this a good deal?
Charlie1520
08-14-2006 06:29:25
 Re: 1972 Jd 2010 with loader and 14.5' backhoe in reply to jdb wisconsin, 08-13-2006 18:14:50
I didn't think they made a JD2010 in '72. Could it be a JD2020? That would be a better choice in tractors.
jdemaris
08-14-2006 06:27:16
If you have a Deere 2010 that was actually made in 1972, it ought to be worth a fortune as a collector's item. 2010 crawler was replaced by the 450 around 1966, and the 2010 wheel tractor was replaced the Ag. 2020 or the Industrial 400 in 66. In regard to the hoe, if it has a barrel-swing cylinder, it's one of the worst Deere ever made. In my area, a 2010 wheel tractor with hoe is worth around $5000 if in very good condition, but I often see them in the $2500 price range. Crawler-loaders not much different, but 2010 dozers with 6-way blades and HL-R trans. bring more.
msb
08-13-2006 18:23:04
Well considering the last 2010 was built in 1965 and if the hoe is a model 50 or 51 parts are no longer available and neither hoe model was very good even when new, the tractor is about $4500 too high.For that kind of money ,look for a 580CK Case.Its a much better hoe.
